Mercedes Benz 1/14 Scale Delivery Truck - KIT from Tamiya - TAM56307
Version Info: This truck is a KIT. Assembly and painting is required. A plain white cab comes out of the box ready for paint. Photos show a completed and painted model. Minimum 4+ channel radio system, ESC, battery, charger and servos will need to be purchased separately.
Tamiya is world-renowned for producing industry-leading RC scale tractor trucks for generations. The 1850L delivery truck is regarded as a new trend setter with its aerodynamically sophisticated appearance and extremely reliable mechanicsk. Powered by a 540 motor and 3-speed transmission, its durable drivetrain spins the rear axle supported on a realistic leaf spring and shock suspension. The 1850L's metal C-Channel ladder frame keeps the power to the pavement when hauling optional accessories. With its base-white cab and decal set, explore endless customization possibilities to build this KIT from the ground up and create your personalized dream scale hauler!
Your Tamiya truck is backed by Motion RC's world-renowned customer service and technical support. Drive on!
FEATURES:
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 3+ HOURS
540-Sized Motor and 3-Speed Transmission The 540-sized brushed motor applies power through a selectable 3-speed transmission to drive dual rear axles. |
| Exceptional Scale Detail Scale details surround this truck for exceptional realism. |
Rear Axle The axle is supported with leaf spring and shocks. |
| Choose Your Own Paint Colors The cab comes plain white out of the box so you can choose any colors you wish to paint and finish your truck in style. |
1/14 Scale This truck comes in an impressive 1/14 scale. Coming in at close to 2 feet in length, it has an ideal on-road presence while being convenient to transport. |
| Add Your Own Electronics and Drive! Once you add your preferred electronics you're ready for those on-road adventures. |
- Exceptional scale detail and realism brings this truck to life on every level
- Includes a powerful 540-sized brushed motor driven by a 3-speed transmission
- Dual rear axles each supported with leaf spring and shocks
- Cab comes out of the box white so you can paint your chosen custom scheme
- Tamiya Mercedes Benz 1/14 Scale Delivery Truck - KIT
- 4 Channel radio - select a minimum 4 channel radio from our Radio Collection
- 4 Channel receiver - select a minimum 4 channel receiver from our Receiver Collection
- 6 Cell 7.2V NiMH Brushed ESC
- 2x standard size servos - we recommend TWO Hitec HS-311 Plastic Gear Standard Servos
- 6 Cell 7.2V 1600mAh NiMH battery with universal connector
| Model Scale | 1/14 |
| Length | 568mm / 22.3in |
| Width | 202mm / 7.9in |
| Height | N/A |
| Weight (No Battery) | 4010g / 141.4oz |
| Wheelbase | 360mm / 14.1in |
| Ground Clearance | N/A |
| Body | ABS Plastic |
| Chassis | Aluminum |
| Drivetrain | 3-Speed |
| Wheel Size (Diameter x Width) | 83mm x 22mm |
| Wheel Hex Size | N/A |
| Tire Tread | Front: 156mm / Rear: 138mm |
| Bushing Material | Metal and Plastic |
| Suspension | Leaf Spring |
| Shock Type | Friction Damper |
| Transmission | 3-Speed |
| Gear Pitch | N/A |
| Internal Gear Ratio | N/A |
| Final Drive Ratio | 1st gear 32.49:1, 2nd gear 17.76:1, 3rd gear 10.66:1 |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | Gear |
| Ball Bearings | N/A |
| Brakes | Electronic |
| Electronic Speed Control | 6 Cell 7.2V NiMH Brushed ESC (required) |
| Motor | 540-Brushed |
| Battery | 7.2V 1600mAh (required) |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | 2x standard size (required) |
| Radio | 4+ Channel (required) |
| Lights | No |
| Sound | No |
| Water Resistant | N/A |
| Skill Level | Intermediate |
| Assembly Time | 3+ Hours |
| Recommended Environment | On-road, smooth, paved surfaces |
