Official Tamiya 1/14 Scale Mercedes Benz Arocs 3363 Tractor Truck - KIT Thread
  • jbaartz
    • Sep 2020
    • 488
    Mercedes Benz Arocs 3363 1/14 Scale Tractor Truck - KIT from Tamiya - TAM56352
    Version Info: This truck is a KIT. Assembly and painting is required. A plain white cab comes out of the box ready for paint. Photos show a completed and painted model. Minimum 4+ channel radio system, ESC, battery, charger and servo will need to be purchased separately.
    Tamiya is world-renowned for producing industry-leading RC scale tractor trucks for generations. The Tamiya Mercedes Benz Arocs 3363 is powered by a 540 motor and 3-speed transmission, its durable drivetrain spins both rear dually axles supported on a realistic leaf spring and shock suspension. The Mercedes Benz Arocs 3363's metal C-Channel ladder frame keeps the power to the pavement when hauling optional accessories. With its base-white cab and decal set, explore endless customization possibilities to build this KIT from the ground up and create your personalized dream scale hauler!
    Your Tamiya truck is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    540-Sized Motor and 3-Speed Transmission
    The 540-sized brushed motor applies power through a selectable 3-speed transmission to drive dual rear axles.
    Exceptional Scale Detail
    Scale details surround this truck for exceptional realism including accurate interior details such as dashboard and seats.
    Dual Rear Axles
    Each axle is supported with leaf spring and shocks.
    Choose Your Own Paint Colors
    The cab comes plain white out of the box so you can choose any colors you wish to paint and finish your truck in style.
    1/14 Scale
    This truck comes in an impressive 1/14 scale. Coming in at close to 2 feet in length, it has an ideal on-road presence while being convenient to transport.
    Add Your Own Electronics and Drive!
    Once you add your preferred electronics you're ready for those on-road adventures.
    FEATURES:
    • Exceptional scale detail and realism brings this truck to life on every level
    • Accurate interior details such as dashboard and seats
    • Gloss and matte finished metal-plated parts further heighten the model's realism
    • Includes a powerful 540-sized brushed motor driven by a 3-speed transmission
    • Dual rear axles each supported with leaf spring and shocks
    • Cab comes out of the box white so you can paint your chosen custom scheme
    INCLUDES:
    • Tamiya RC Mercedes Benz Arocs 3363 1/14 Scale Tractor Truck - KIT
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 3+ HOURS
    Model Scale 1/14
    Length N/A
    Width N/A
    Height N/A
    Weight (No Battery) N/A
    Wheelbase 272mm / 10.7in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis Semi-Truck
    Drivetrain Rear 2-Axle Drive
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material Metal and Plastic
    Suspension Leaf Spring
    Shock Type Friction Damper
    Transmission 3-Speed
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio 1st gear 32.49:1, 2nd gear 17.76:1, 3rd gear 10.66:1
    Pinion N/A
    Spur Gear N/A
    Differential Gear
    Ball Bearings N/A
    Brakes Electronic
    Electronic Speed Control 6 Cell 7.2V NiMH Brushed ESC (required)
    Motor 540-Brushed
    Battery 7.2V 1600mAh (required)
    Servos 1x standard size (required)
    Radio 4+ Channel (required)
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 3+ Hours
    Recommended Environment On-road, smooth, paved surfaces
