Mercedes Benz Actros 1/14 Scale Semi Truck - KIT from Tamiya - TAM56354
Version Info: This truck is a KIT. Assembly is required. Minimum 4+ channel radio system, ESC, battery, charger and servo will need to be purchased separately.
This is a special edition of the Mercedes-Benz Actros 3363. It features pre-painted Body parts in Pearl Blue (Tamiya Color TS-89) for a cool look, with a durable coating applied to protect the paintwork from damage.
Tamiya is world-renowned for producing industry-leading RC scale tractor trucks for generations. The Tamiya Mercedes Benz Actros is powered by a 540 motor and 3-speed transmission, its durable drivetrain spins both rear dually axles supported on a realistic leaf spring and shock suspension. The Mercedes Benz Actros' metal C-Channel ladder frame keeps the power to the pavement when hauling optional accessories. Your Tamiya truck is backed by Motion RC's world-renowned customer service and technical support. Drive on!
540-Sized Motor and 3-Speed Transmission The 540-sized brushed motor applies power through a selectable 3-speed transmission to drive dual rear axles. |
| Exceptional Scale Detail Scale details surround this truck for exceptional realism. |
Dual Rear Axles Each axle is supported with leaf spring and shocks. |
| LED Light Buckets You can install your own LED lights (sold separately) to further the scale appeal. |
1/14 Scale This truck comes in an impressive 1/14 scale. Coming in at close to 2 feet in length, it has an ideal on-road presence while being convenient to transport. |
| Add Your Own Electronics and Drive! Once you add your preferred electronics you're ready for those on-road adventures. |
- Exceptional scale detail and realism brings this truck to life on every level
- The 3-axle Actros body is expertly recreated, including roof and bumper auxiliary lights
- Body, F, K, M and H parts are replaced with pre-painted Pearl Blue parts. They have been given a urethane top coat for a superb finish
- The tried and tested Tamiya 3-axle chassis utilizes a tough ladder frame with aluminum side channels and resin cross members
- 3-speed transmission can be controlled via 4ch R/C transmitter
- Metal leaf spring dampers with built-in coil springs provide durable suspension
- Coupler is included to enable connection with any currently available Tamiya 1/14 scale trailer
- Compatible with separately-sold Multi-Function Control Unit MFC-03 or MFC-01 for realistic LED lights and sounds
- Tamiya Mercedes Benz Actros 1/14 Scale Semi Truck - KIT
- 4 Channel radio - select a minimum 4 channel radio from our Radio Collection
- 4 Channel receiver - select a minimum 4 channel receiver from our Receiver Collection
- 6 Cell 7.2V NiMH Brushed ESC
- Standard size servo - we recommend the Hitec HS-311 Plastic Gear Standard Servo
- 6 Cell 7.2V 1600mAh NiMH battery with universal connector
- 6 Cell compatible battery charger - select a minimum 6 cell (6S) charger from our Charger Collection
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 3+ HOURS
| Model Scale | 1/14 |
| Length | 538mm / 21.1in |
| Width | 195mm / 7.6in |
| Height | 305mm / 12.0in |
| Weight (No Battery) | N/A |
| Wheelbase | 272mm / 10.7in |
| Ground Clearance | N/A |
| Body | ABS Plastic |
| Chassis | Aluminum & Plastic |
| Drivetrain | 3-Speed |
| Wheel Size (Diameter x Width) | N/A |
| Wheel Hex Size | N/A |
| Tire Tread | N/A |
| Bushing Material | Metal and Plastic |
| Suspension | Leaf Spring |
| Shock Type | Friction Damper |
| Transmission | 3-Speed |
| Gear Pitch | N/A |
| Internal Gear Ratio | N/A |
| Final Drive Ratio | 1st gear 32.49:1, 2nd gear 17.76:1, 3rd gear 10.66:1 |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | Gear |
| Ball Bearings | N/A |
| Brakes | Electronic |
| Electronic Speed Control | 6 Cell 7.2V NiMH Brushed ESC (required) |
| Motor | 540-Brushed |
| Battery | 7.2V 1600mAh (required) |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | 1x standard size (required) |
| Radio | 4+ Channel (required) |
| Lights | No |
| Sound | No |
| Water Resistant | N/A |
| Skill Level | Intermediate |
| Assembly Time | 3+ Hours |
| Recommended Environment | On-road, smooth, paved surfaces |
