Official Tamiya 1/14 Scale NYK Container Trailer Plastic Model - KIT Thread
  • jbaartz
    • Sep 2020
    • 488
    NYK Container Trailer 1/14 Scale Plastic Model - KIT from Tamiya - TAM56330
    Version Info: This trailer is a KIT. Assembly is required.
    Nippon Yusen Kaisya (NYK) is one of the largest shipping companies in the world. This is the Tamiya replica in 1/14 scale and it is the second container model released in the Tractor Trailer R/C category.
    The container features an aluminum frame with durable ABS front, top, and side panels. The well-known NYK logos are reproduced on the included vinyl sticker sheet, and the container can be detached from the semi-trailer after assembly. The 3-axle semi-trailer chassis comes with a realistically reproduced leaf-spring suspension. This semi-trailer can be connected to any Tamiya 1/14 R/C Tractor Truck and a variety of Option Parts can also be installed for enhanced realism.
    Hitch Up To a Tamiya 1/14 Scale R/C Tractor Truck
    Hitch this trailer up to any compatible Tamiya 1/14 scale truck for an exceptional scale experience both static and on the road.
    Exceptional Scale Detail
    Scale details surround this trailer for exceptional realism.
    Detachable Container
    Container can be detached from the semi-trailer after assembly.
    Optional Light and Sound
    Add your own light and sound package with the separately-sold Multi-Function Control Unit MFC-01 or MFC-03.
    FEATURES:
    • Aluminum frame with durable ABS front, top, and side panels
    • The well-known NYK logos are reproduced on the included vinyl sticker sheet
    • Container can be detached from the semi-trailer after assembly
    • The 3-axle semi-trailer chassis comes with a realistically reproduced leaf-spring suspension
    • Can be connected to any Tamiya 1/14 R/C Tractor Truck
    • A variety of optional parts can also be installed for enhanced realism
    INCLUDES:
    • Tamiya NYK Container Trailer 1/14 Scale Plastic Model - KIT
    REQUIRES:
    • Tamiya 1/14 Scale Tractor Trailer Truck
    PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 3+ HOURS
    Model Scale 1/14
    Length N/A
    Width N/A
    Height N/A
    Weight (No Battery) N/A
    Wheelbase N/A
    Ground Clearance N/A
    Body ABS Plastic
    Chassis Aluminum
    Drivetrain N/A
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material Metal and Plastic
    Suspension Leaf Spring
    Shock Type Friction Damper
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor N/A
    Battery N/A
    Servos N/A
    Radio N/A
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 3+ Hours
    Recommended Environment On-road, smooth, paved surfaces
