Official Tamiya 1/14 Scale Pole Trailer Scale Plastic Model - KIT Thread
  • jbaartz
    • Sep 2020
    • 488
    Pole Trailer 1/14 Scale Plastic Model - KIT from Tamiya - TAM56310
    Version Info: This trailer is a KIT. Assembly is required.
    The Pole-Trailer is able to carry pipes of various lengths due to its collapsible pole. The trailer also features an aluminum chassis and 4 highly detailed wheels. 5 plastic pipes of 55mm in diameter and 75cm in length are included.
    Hitch Up To a Tamiya 1/14 Scale R/C Tractor Truck
    Hith this trailer up to any compatible Tamiya 1/14 scale truck for an exceptional scale experience both static and on the road.
    Exceptional Scale Detail
    Scale details surround this trailer for exceptional realism.
    5 Plastic Pipes Included
    Optional Light and Sound
    Add your own light and sound package with the separately-sold Multi-Function Control Unit MFC-01 or MFC-03.
    FEATURES:
    • Able to carry pipes of various lengths due to its collapsible pole
    • Aluminum chassis and 4 highly detailed wheels
    • 5 plastic pipes of 55mm in diameter and 75cm in length are included
    INCLUDES:
    • Tamiya Pole Trailer 1/14 Scale Plastic Model - KIT
    REQUIRES:
    • Tamiya 1/14 Scale Tractor Trailer Truck
    PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 3+ HOURS
    Model Scale 1/14
    Length 709mm / 27.9in
    Width 186mm / 7.3in
    Height N/A
    Weight (No Battery) 2550g / 89.9oz
    Wheelbase N/A
    Ground Clearance N/A
    Body N/A
    Chassis Aluminum
    Drivetrain N/A
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material Metal and Plastic
    Suspension Leaf Spring
    Shock Type Friction Damper
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor N/A
    Battery N/A
    Servos N/A
    Radio N/A
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 3+ Hours
    Recommended Environment On-road, smooth, paved surfaces
