Pole Trailer 1/14 Scale Plastic Model - KIT from Tamiya - TAM56310
Version Info: This trailer is a KIT. Assembly is required.
The Pole-Trailer is able to carry pipes of various lengths due to its collapsible pole. The trailer also features an aluminum chassis and 4 highly detailed wheels. 5 plastic pipes of 55mm in diameter and 75cm in length are included.
Hitch Up To a Tamiya 1/14 Scale R/C Tractor Truck Hith this trailer up to any compatible Tamiya 1/14 scale truck for an exceptional scale experience both static and on the road. |
| Exceptional Scale Detail Scale details surround this trailer for exceptional realism. |
5 Plastic Pipes Included 5 plastic pipes of 55mm in diameter and 75cm in length are included. |
| Optional Light and Sound Add your own light and sound package with the separately-sold Multi-Function Control Unit MFC-01 or MFC-03. |
- Able to carry pipes of various lengths due to its collapsible pole
- Aluminum chassis and 4 highly detailed wheels
- 5 plastic pipes of 55mm in diameter and 75cm in length are included
- Tamiya Pole Trailer 1/14 Scale Plastic Model - KIT
- Tamiya 1/14 Scale Tractor Trailer Truck
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 3+ HOURS
| Model Scale | 1/14 |
| Length | 709mm / 27.9in |
| Width | 186mm / 7.3in |
| Height | N/A |
| Weight (No Battery) | 2550g / 89.9oz |
| Wheelbase | N/A |
| Ground Clearance | N/A |
| Body | N/A |
| Chassis | Aluminum |
| Drivetrain | N/A |
| Wheel Size (Diameter x Width) | N/A |
| Wheel Hex Size | N/A |
| Tire Tread | N/A |
| Bushing Material | Metal and Plastic |
| Suspension | Leaf Spring |
| Shock Type | Friction Damper |
| Transmission | N/A |
| Gear Pitch | N/A |
| Internal Gear Ratio | N/A |
| Final Drive Ratio | N/A |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | N/A |
| Ball Bearings | N/A |
| Brakes | N/A |
| Electronic Speed Control | N/A |
| Motor | N/A |
| Battery | N/A |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | N/A |
| Radio | N/A |
| Lights | No |
| Sound | No |
| Water Resistant | N/A |
| Skill Level | Intermediate |
| Assembly Time | 3+ Hours |
| Recommended Environment | On-road, smooth, paved surfaces |
