Official Kyosho 1/8 Scale USA-1 VE Monster Truck 4WD RTR Thread
    • 8218
    USA-1 VE 1/8 Scale 4WD Monster Truck - RTR from Kyosho - KYO34257
    Version Info: This car is delivered as "RTR", however it does require 4x AA batteries for the transmitter, and TWO 7.4V LiPo 5000mAh batteries with a T-Connector in series for the chassis (see Requires below for details).
    Born in the USA, the monster truck symbolizes America: big, bold and powerful! With pickup truck bodies emblazoned with dynamic motifs mounted on super tough chassis structures and big engines to power huge tires, monster truck racing filled and thrilled stadiums around America and the world with their awesome power and speed. Recreated in 1/8 scale as an R/C truck, the “USA-1” flies the American flag loud and proud as the recognized symbol of monster trucking. Dating back to the 1990’s, Kyosho’s earlier versions have been fully renewed with a newly created ULTRA SCALE body, uniquely reinforced 5-link suspension and stronger solid axles originally used on the Mad Crusher and FO-XX 2.0.
    Equipped with a high-power brushless motor with a 4-pole rotor and 12-slot stator generating 2300KV, the VE (electric power version) delivers outrageous speed and power characteristics that would rival that of the real USA-1. The high-powered unit produces dynamic performance that makes the large 570mm body length of the USA-1 feel smaller with acceleration pickup from a standing start surpassing that of the GP (engine powered) version. As a pre-assembled Readyset, the body is immaculately finished with paint and livery to capture the rich sense of scale of this iconic 1990’s machine. A charged battery and batteries for the transmitter are all that is required to start the action. With spare parts and a wide range of optional parts available to continually maintain and enhance performance, your USA-1 will provide thrilling fun over a long time and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Durability and Power
    Reinforced transmission housings for the front and rear, thrives under the increased power while improving crash resistance. Conversion to 4WS (four-wheel steering) can also be achieved with optional parts. The incredibly strong front and rear differentials come from a 1:8-scale world champion off-road racer and feature metal ring and pinion gears, plus four internal metal spider gears for the ultimate in durability.
    Higher Performance
    The newly developed 2300 KV KYOSHO SPEED HOUSE TORX8+ brushless motor generates approximately 4400 RPM at 14.8v than the previous TORX8 motor used in the Mad Crusher VE. The red color of the motor distinguishes it as the higher performance of the TORX8+ series.
    Waterproof and Configurable ESC
    Equipped with a KYOSHO SPEED HOUSE BRAINZ 8 waterproof ESC (speed controller). With maximum voltage of 14.8V (2 x 2S Lipo packs); settings for brake, advance angle, punch force, cutoff voltage, etc., can be adjusted.
    Accurate Wheel Design
    The USA-1 includes accurate reproductions of the 66-inch agriculture tires and white wheels that were featured on the real USA-1 throughout its career. Foam inserts are installed inside the tires to maximize handling on a variety of surfaces.
    • Pre-assembled chassis with R/C system installed and finished body. Includes pistol-grip Synchro KT-231P+ transmitter
    • Five-link suspension in combination with shaft-type 4WD delivers exceptional stability over rough surfaces
    • Equipped with KS5031-09MW servo, featuring high durability metal gears
    • Ultra-realistic scale body has been recreated under license of USA-1, including the signature color scheme
    • Optional LED light set shines bright with LED head & tail lamps and rooftop fog lamps
    • Brushless motor unit is designed to handle a massive 14.8V (4S). Optional twin motor setup is also possible
    • Front center drive features a telescopic universal shaft to ensure high drive efficiency and prevent shaft dropout issues
    • Optional 4WS (four wheel steering) increases turning power. A wide range of other options are also available
    • Equipped with a wheelie bar to prevent the machine from flipping over backwards during hard acceleration. Enjoy the powerful action of the truck running on its two rear wheels
    • Charger and battery for the motor, as well as 4 x AA batteries for transmitter are required for operation
    • Engine-powered version using the same body and chassis components is also available
    • Kyosho USA-1 VE 1/8 Scale 4WD Monster Truck - RTR
    • Factory assembled printed body
    • 2.4GHz Syncro KT-231P+ transmitter
    • L-shape hex wrenches: 1.5, 2.0, 2.5, 3.0mm
    • Cross wrench
    • 17mm wheel wrench
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :1 hour
    Model Scale 1/8
    Length 567mm / 22.3in
    Width 455mm / 17.9in
    Height 297mm / 11.6in
    Weight (No Battery) 5040g / 177.7oz
    Wheelbase 360mm / 14.1in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis 4WD
    Drivetrain N/A
    Wheel Size (Diameter x Width) 164mm x 104mm
    Wheel Hex Size N/A
    Tire Tread 339mm / 343mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 8.68:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control 60A
    Motor Kyosho Speed House TORX8 Brushless Motor
    Battery 4x AA alkaline and TWO 2 Cell 7.4V LiPo batteries in series (required)
    Servos N/A
    Radio Syncro KT-331P transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
