Official HPI Racing 1/10 Scale Jumpshot V2 Toyo Tires Edition 2WD Short Course Truck Thread
    • 8228
    Jumpshot V2 Toyo Tires Edition 1/10 Scale 2WD Short Course Truck - RTR from HPI Racing - HPI160267
    Version Info: This car is delivered as "RTR", however it does require 4 x AA batteries for the transmitter, a 2S (7.4V) LiPo battery and a battery charger, purchased separately (see Requires below for details).
    Motion RC offers HPI Racing’s Jumpshot V2 Short course Truck with an awesome officially-licensed Toyo Tires trim scheme and realistic Open Country MT replica tires. The detailed and durable factory-decorated and licensed bodyshell represents an iconic off-road truck livery, and with a brand new, super-powerful, 12-turn, 550-size motor, the Jumpshot V2 trucks have tons of power for additional fun. The larger brushed motor delivers tons of extra torque for fast acceleration and maximum jumping power, and the 12-turn construction means you'll get extra-high RPM for ballistic top speeds! Enhanced gearing from the new and improved pinion & spur gear combination means you get the best of both worlds: wild acceleration from a standing start, plus crazy fast top-end speed. Completely assembled and ready for your selection of battery and charger, the Jumpshot is ready to deliver hours of trouble-free fun.
    Easy to Drive
    The Jumpshot SC V2 is super-easy to drive and get familiar with – all you have to do is plug in the battery of your choice, then switch on the radio and car. It’s that easy!
    Protected Motor and Transmission
    HPI have installed a new gear cover on the optimized rear-mounted gearbox to protect the all-important internal moving parts from dust and debris.
    Heavy-Duty Metal Gears
    HPI improved everything inside the Jumpshot SC V2 gearbox with new metal top and middle transmission gears with a revised tooth profile for improved gear mesh and lower rolling resistance, in addition to a new aluminum motor mount plate.
    TVP Chassis Layout
    With durable front and rear skid plates, reinforced battery box door and Savage-inspired TVP (twin vertical plate) lightweight aluminum chassis, the Jumpshot SC V2 is made to tame any terrain. Durable yet flexible suspension parts absorb punishment without breaking, with impact-resistant wheels designed to resist cracking under pressure.
    • Factory-built RTR 2WD short course truck
    • Metal top & middle transmission gears
    • Revised tooth profile for improved gear mesh and lower rolling resistance
    • New composite differential – Sealed, oil-filled 4-bevel gear design
    • Fully enclosed spur gear cover with slipper clutch access cap
    • New transmission case with metal motor mount plate
    • Short Course truck style body with officially licensed Toyo Tires livery
    • 1/10th scale replica Open Country M/T off road tires
    • Tough aluminum TVP chassis design
    • Bottom-loading battery box fits 2S LiPo packs
    • 12-turn 550-size motor for maximum power
    • HPI SC-3SWP2 waterproof LiPo-ready ESC
    • Enclosed receiver box
    • 4 GHz radio system
    • Oil-filled shock absorbers
    • Double-wishbone suspension design
    • Sturdy body mounts
    • Standard 12mm wheel hub drive hex
    • Black 8-spoke wheels
    • HPI Racing Jumpshot V2 Toyo Tires Edition 1/10 Scale 2WD Short Course Truck - RTR
    • HPI pistol-grip transmitter, with interference-free 2.4GHz technology
    • HPI 12-turn 550-size brushed motor
    • HPI SS-20WR waterproof servo
    • Complete ball bearings
    AGE LEVEL: 10 and up
    SKILL LEVEL: Beginner
    BUILD TIME: Less than 30 minutes
    Model Scale 1/10
    Length 560mm / 21.8in
    Width 295mm / 11.5in
    Height 190mm / 7.4in
    Weight (Without Battery) 1950g / 68.7oz
    Wheelbase 335mm / 13.1in
    Ground Clearance N/A
    Body Polycarbonate, factory painted and decorated
    Chassis Aluminum TVP
    Drivetrain 2WD
    Wheel Size (Diameter x Width) 134 x 70mm
    Wheel Hex Size 14mm
    Tire Tread Multi-surface
    Bushing Material N/A
    Suspension 4-wheel independent
    Shock Type Oil Filled, Coil Over, Adjustable
    Transmission N/A
    Gear Pitch 48p
    Internal Gear Ratio 2.72:1
    Final Drive Ratio 14.40:1
    Pinion 17T
    Spur Gear 90T
    Differential Composite Gear Differential
    Ball Bearings Complete
    Brakes Electronic
    Electronic Speed Control SC-3SWP2 waterproof LiPo-ready ESC
    Motor 550 brushed
    Battery 2S LiPo with T- connector (required)
    Max Battery Dimensions (L x W x H) 140 x 50 x 30mm
    Servos Waterproof, Metal Gear
    Radio 2 Channel (included)
    Lights No
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time Less than 30 minutes
