Official Roc Hobby 1/12 Scale 1941 MB Willys 4WD Truck RTR Thread
    • 8228
    1941 MB Willys 1/12 Scale 4WD Truck - RTR from Roc Hobby - FMS11201RTR
    Version Info: This vehicle is delivered as “RTR” but requires the additional purchase of 4 (four) AAA alkaline batteries for the transmitter.
    The FMS 1/12 MB Willys Scaler 4WD RTR from Motion RC is an ideal choice for scale adventure, designed after the iconic military battlefield workhorse that was made between 1940 and 1945. Decorated in the realistic olive drab colorway with white decals to resemble those used during WWII, you can be confident that no details were left out on this scale model. The injected molded body features functional LED lights, servo-driven steering wheel, realistic axe and shovel secured with fabric straps, detailed dashboard gauges, tilt-up body for easy equipment access, fold away windshield and more. This FMS MB Scaler truly allows you to make your own trail.
    The chassis utilizes a solid metal ladder frame with realistic multi-leaf springs and dampeners for superb scale fidelity. The tires feature a realistic tread pattern for both performance and looks, powered by a 180-sized brushed motor that is paired with a 2-in-1 receiver/ESC unit. Additional outstanding features include a low-battery warning, transmitter “left-on” alarm, motor overload protection, and more. A 7 piece LED lighting package adds realism and allows nighttime operation, while the 1/12 scale size is ideal for use with various scale military driver figures (not included).
    Combine the versatile, go-anywhere fun of the FMS 1941 MB Willys 1/12 Scale 4WD Truck with Motion RC’s industry-leading customer service and product support for a package that cannot be beat!
    Comfortable, Reliable 2.4GHz Transmitter
    Never worry about interference thanks to the solid control link provided by the 2.4GHz radio system.
    Realistic Leaf Spring Suspension
    Roc Hobby did not sacrifice scale fidelity and realism thanks to the multi-leaf spring steel suspension and shift on the fly 2-speed transfer case.
    Capable Crawler
    Tackle most any terrain thanks to the two-speed transmission, high-grip tires, and outstanding torque delivered by the brushed motor.
    Fully Detailed Interior
    Get real and enjoy the unique and realistic driving experience of the Roc Hobby 1941 Willys MB Scaler.
    • Authentic full-time 4WD with 2-speed transmission
    • Injection-molded Army olive drab body finished with delicate pad-printed graphics
    • Realistic scale detailing including canvas seats, rear-view mirrors, dashboard gauges, leaf springs & dampers, scale-appropriate wheels and tires, along with metal ladder frame rails
    • Additional scale features and accessories include canvas-covered front and rear seats, axe, shovel, two storage bins, foldable windscreen, and servo-operated rotating steering wheel
    • Ideal for use with 1/12 scale military figures for additional realism
    • Seven LED lights are included for nighttime operation
    • Roc Hobby 1941 MB Willys 1/12 Scale 4WD Truck - RTR
    • FMS 2.4GHz Pistol-Grip Transmitter
    • FMS 2-in-1 RX/ESC
    • FMS Steering Servo
    • FMS Steering Wheel Servo
    • FMS 2-speed Shift Servo
    • FMS Hi-Torque 180-size Brushed Motor
    • 7.4V 380mAh LiPo Battery
    • USB battery Charger
    Requires:
    • 4x AAA Alkaline batteries for transmitter
    Product Specifications:
    AGE LEVEL: 14 and up
    SKILL LEVE: Beginner
    BUILD TIME: Less than 15 minutes
    Model Scale 1/12
    Length 278mm / 10.9in
    Width 136mm / 5.4in
    Height 140mm / 5.5in
    Weight (No Battery) N/A
    Wheelbase 169mm / 6.6in
    Ground Clearance 24mm / 0.9in
    Body Injection molded ABS plastic, factory painted with clear windows
    Chassis Metal/Composite scale-type
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 88mm x 33mm
    Wheel Hex Size N/A
    Tire Tread Scale
    Bushing Material N/A
    Suspension Metal Leaf Spring
    Shock Type Friction damper
    Transmission 4WD Shaft-driven
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential Gear
    Ball Bearings Yes
    Brakes Electronic
    Electronic Speed Control Brushed 2-in-1 RX/ESC (included)
    Motor 180-size brushed
    Battery 7.4V 380mAh LiPo
    Servos 3x 1Kg High-Torque Servos
    Radio 2 Channel
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time Less than 15 minutes
    Recommended Environment Indoors/Outdoors
