Official FMS 1/12 Scale Suzuki Jimny 4WD Crawler RTR Thread
    • 8233
    Suzuki Jimny 1/12 Scale 4WD Crawler - RTR from FMS - FMS11221RTR
    Version Info: This vehicle is delivered as “RTR” but requires the additional purchase of 4 (four) AAA alkaline batteries for the transmitter.
    The officially-licensed FMS Suzuki Jimny 1/12 Scale 4WD Crawler RTR from Motion RC is an ideal choice for scale adventure, offering working and static details that set this model apart from the crowd! Features include a realistic LED light set with high and low-beam headlights, fog lamps, taillights, turn signals, brake lights, and backup lamp. Folding rear seats with hidden storage trunk, movable front seats, servo-controlled steering wheel, realistic engine details, retractable sideview mirrors, and operational side and rear doors combine to make this masterpiece a truly exceptional scale model. In addition, factory-correct paint, photo-etched grille, and electro-plate Suzuki badges add an extraordinary level of realistic scale detail.
    The beautiful scale details are complimented by outstanding running gear. A solid, full-frame chassis design with metal frame rails, 3-link rigid axle suspension with oil-filled, coil-over dampers, metal gears with u-joint driveshafts, and 25 stainless steel ball bearings efficiently transfer the power of the optimized 180-class brushed motor through a 2-speed, transmitter-controlled transfer case. The 2-in-1 receiver/ESC unit offers precise and reliable control, while the 1/12 scale size is ideal for use with various driver doll figures (not included).
    Combine the versatile, go-anywhere fun of the Suzuki Jimny 1/12 Scale 4WD Crawler RTR with Motion RC’s industry-leading customer service and product support for a package that cannot be beat!
    Comfortable, Reliable 2.4GHz Transmitter
    Never worry about interference thanks to the solid control link provided by the 2.4GHz radio system.
    Comprehensive LED Light Set
    The Jimny features a complete LED light set with high and low-beam headlights, fog lamps, taillights, turn signals, brake lights, and backup lamp.
    Incredible Scale Details
    Factory-correct paint, photo-etched grille, and electro-plate Suzuki badges add an extraordinary level of realistic scale detail to the 1/12 Jimny.
    Operational Side and Rear Doors
    Operating side and rear doors combine to make this officially-licensed model a truly exceptional scale experience.
    • Officially licensed product of the Suzuki Motor Corporation
    • Ready-to-Run 4WD
    • Factory-correct painted body with photo-etched emblems
    • Authentic movable rear-view mirror
    • Natural rubber tires on scale wheels
    • Bumpers, wheel arches, and roof can be disassembled for personalization
    • Comprehensive, transmitter-controlled lighting system with 15 LEDs
    • Scale dummy engine hides the 180 motor and two-speed transmission
    • Realistic side and rear opening doors
    • Servo-operated steering wheel linked proportionately to the steering rack
    • Adjustable front seats, a perfect match for 1:12 driver dolls.
    • Spacious storage trunk below fold-down rear seats
    • Detailed interior and dashboard
    • Full-frame chassis structure with metal frame rails
    • Front & rear 3-link rigid axle suspension with coil spring
    • Metal transmission and ring & pinion gears
    • 25 piece stainless steel ball bearing set
    • Metal U-joint driveshafts
    • Battery, servo, receiver, ESC, and light control board conveniently located under the hood
    • FMS Suzuki Jimny 1/12 Scale 4WD Crawler - RTR
    • FMS 2.4GHz Pistol-Grip Transmitter
    • FMS 2-in-1 RX/ESC
    • FMS Steering Servo
    • FMS Steering Wheel Servo
    • FMS 2-speed Shift Servo
    • FMS Hi-Torque 180-size Brushed Motor
    • 7.4V 380mAh LiPo Battery
    • USB battery Charger
    Requires:
    • 4x AAA Alkaline batteries for transmitter
    Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :beginner
    BUILD TIME :less than 15 minutes
    Model Scale 1/12
    Length 291mm / 11.3in
    Width 135mm / 5.3in
    Height 158mm / 6.2in
    Weight (No Battery) 985g / 35.1oz
    Wheelbase 187mm / 7.3in
    Ground Clearance 16mm / 0.6in
    Body Injection molded ABS plastic, factory painted with clear windows
    Chassis Metal/Composite scale-type
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 60mm x 15mm
    Wheel Hex Size N/A
    Tire Tread Scale
    Bushing Material N/A
    Suspension Fixed Axle
    Shock Type Oil-filled damper
    Transmission 4WD Shaft-driven
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential No
    Ball Bearings Yes
    Brakes Electronic
    Electronic Speed Control Brushed 2-in-1 RX/ESC (included)
    Motor 180-size brushed
    Battery 7.4V 380mAh LiPo
    Servos 3x 1Kg High-Torque Servos
    Radio 2 Channel
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time Less than 15 minutes
    Recommended Environment Indoors/Outdoors
