Official FMS 1/18 Scale Toyota FJ Cruiser 4WD Crawler RTR Thread
    Toyota FJ Cruiser 1/18 Scale 4WD Crawler - RTR from FMS - FMS11806RTR
    Version Info: This vehicle is delivered as “RTR” but requires the additional purchase of 4 (four) AAA alkaline batteries for the transmitter.
    The officially-licensed FMS Toyota FJ Cruiser 1/18 Scale 4WD Crawler RTR from Motion RC is an ideal choice for scale adventure, offering working and static details that create an exceptional modeling experience! Features include a realistic LED light set with headlights, turn signals, and brake lights. The injection-molded hard plastic body contains scale details such as a snorkel, windshield wipers, mirrors, roof rack, useable rear-mounted spare tire, heavy-duty front bumper, functional hood, and accurately-scaled footrests. Full interior details include realistic seats and dashboard that complement this truly exceptional scale model.
    The scale details are complimented by outstanding running gear. Metal frame rails, link-style solid axle suspension with coil-over dampers, chassis-mounted steering servo, and an efficient center gearbox to transfer the power of the optimized 180-class brushed crawling motor to the ground. Super-soft tires on real beadlock wheels deliver the grip and conformity required to traverse the most difficult climbs, and the 2-in-1 receiver/ESC unit delivers the precise and reliable control needed to climb with confidence.
    Combine the versatile, go-anywhere fun of the Toyota FJ Cruiser 1/18 Scale 4WD Crawler RTR with Motion RC’s industry-leading customer service and product support for an unbeatable package!
    LED Light Set
    The FJ features a complete LED light set with headlights, turn signals, and brake lights for when the trail gets dark.
    Blaze your own trail
    Just like its 1:1 scale namesake, the FMS Toyota FJ is rugged and ready for most any off-road adventure!
    Generous Ground Clearance
    The FJ delivers sufficient ground clearance to confidently forge small streams or ponds.
    Comfortable, Reliable 2.4GHz Transmitter
    Never worry about interference thanks to the solid control link provided by the 2.4GHz radio system.
    • Officially-licensed by Toyota Motor Corporation
    • Injection-molded hard body with factory-correct colorway
    • Chassis-mounted servo
    • Functioning hood
    • Scale side mirrors, snorkel, running boards, and windshield wipers
    • Molded Front and Rear Bumper, Roof Rack, Ladder and Running Boards
    • Factory-installed LED light system
    • Functional spare tire
    • High-traction ultra-soft scale tires on 1.0" beadlock wheels
    • Optimized 55T brushed crawler motor
    • 2S 7.4V 380 mAh LiPo delivers up to 30 minutes of run time per charge
    • FMS Toyota FJ Cruiser 1/18 Scale 4WD Crawler - RTR
    • FMS 2.4GHz Pistol-Grip Transmitter
    • FMS 2-in-1 RX/ESC
    • FMS Steering Servo
    • FMS Hi-Torque 180-size Brushed Motor
    • 7.4V 380mAh LiPo Battery
    • USB battery Charger
    Requires:
    • 4x AAA Alkaline batteries for transmitter
    Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :beginner
    BUILD TIME :less than 15 minutes
    Model Scale 1/18
    Length 278mm / 10.8in
    Width 118mm / 4.6in
    Height 131mm / 5.1in
    Weight (No Battery) 423g / 15.1oz
    Wheelbase 187mm / 7.3in
    Ground Clearance 38mm / 1.4in
    Body Injection molded ABS plastic, factory painted with clear windows
    Chassis Metal/Composite scale-type
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 56mm x 16mm
    Wheel Hex Size N/A
    Tire Tread Scale
    Bushing Material Bronze
    Suspension Fixed axle
    Shock Type Oil-filled damper
    Transmission 4WD Shaft-driven
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio 84:1
    Pinion N/A
    Spur Gear N/A
    Differential No
    Ball Bearings No
    Brakes Electronic
    Electronic Speed Control Brushed 2-in-1 RX/ESC (included)
    Motor 180-Size Brushed
    Battery 7.4V 380mAh LiPo
    Servos 1Kg High-Torque Servo
    Radio 2 Channel
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time Less than 15 minutes
    Recommended Environment Indoors/Outdoors
