Official Kyosho Mad Wagon 1/10 Scale 4WD Truck RTR Thread
    • 8218
    Mad Wagon 1/10 Scale 4WD Truck - RTR from Kyosho
    Version Info: This truck is delivered as "RTR", however does require 4x AA batteries for the transmitter, a 7.4V 5000mAh LiPo battery and a battery charger, purchased separately (see Requires below for details).
    The Monster Truck, otherwise referred to as the ‘Basher’ category, has grown in popularity over many generations. With a pickup truck body mounted on a tough chassis and large diameter tires, monster trucks including R/C model versions, are built to go anywhere from the badlands to stadium courses. Now the Mad Wagon VE puts a unique style on a brute R/C machine! The completely new KB10 4WD chassis design is compatible with 3S (11.1V) high-power lithium polymer (LiPo) batteries and features a newly developed brushless motor and speed controller as standard.
    Delivering an optimal balance of high-speed and power, the aluminum main chassis of the KB10 combines front/rear blocks incorporating a split frame and double wishbone suspension to drive the all-terrain 2.8” wheels and tires. As the tire size is compatible with standard wheels, you can vary specifications to suit the type of road surface and conditions. In addition, drivetrain parts are comparable to the 1/8 scale Inferno NEO ST 3.0 parts, providing more than enough capacity for a 1/10 scale machine. The original 1980’s style van body design is produced in ‘Ultra Scale’ realism.
    While the body included in the kit is pre-painted, you could create your own custom body coloring design with a clear body as well as elevating the realism with the optional LED light unit (No.97054-4B). The Mad Wagon VE is packaged as a pre-assembled Readyset and requires only batteries for the chassis and charger to get up and running. A wide range of optional parts are available to expand and extend your enjoyment of the R/C car hobby and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    High Rigidity Chassis
    Aluminum main chassis combines with the superior pitch rigidity of the vertical resin frame to create a high-strength structure that delivers optimal balance of high rigidity and suppleness.
    Ultra Scale Body
    Based on 1980’s era van styling, this newly designed body is made from durable polycarbonate and finished with paint scheme and decals applied. A separately molded grille and light parts enhance the realism of this “Ultra Scale Body”.
    TORX 10L Brushless Motor
    Includes newly developed TORX 10L brushless motor. With 38mm diameter and long 68mm specifications, the motor produces 2850Kv (rotations per volt) and efficiently converts power from the 3S LiPo battery into speed and torque.
    BRAINZ 10+ waterproof ESC
    Equipped with a BRAINZ 10+ waterproof ESC (speed controller) that boasts 80A capacity. Top mounted cooling fan manages heat generation to reduce power loss even with extended running times.
    • Readyset includes pre-assembled chassis, painted body, and RC system with pistol grip Syncro KT-231P + transmitter
    • Features powerful brushless motor unit that reaches a maximum speed of 75km/h.
    • Includes original design wagon-type body. There are two color variations, and a clear body is also available as an option
    • Newly designed chassis incorporates a shaft-type 4WD with a proven double wishbone suspension to deliver exceptional driving performance
    • Fully equipped with (22) ball bearings as standard specification for superior drive efficiency
    • Equipped with lightweight resin telescopic universal shafts on all four wheels to reduce drive loss and prevent drive shaft drop outs in contact
    • Newly designed 2.8 inch tires and wheels. Standard specification 1/10 scale 2.8 inch tires and wheels can also be installed
    • A wide range of gear ratios can be selected by changing the standard gears included in the kit
    • Rear of the machine is fitted with wheelie bar that prevents the truck from flipping from sudden acceleration
    • Kyosho Mad Wagon VE Grey KB10W 1/10 Scale 4WD Truck - RTR
    • Factory assembled chassis complete with control linkages
    • Pre-cut and painted body complete with decals applied
    • 2.4GHz Syncro KT-231P+ transmitter
    • 1.5mm/2.0mm/2.5mm L shaped hex wrench
    • Cross wrench
    • 4/5/5.5/7/10mm Integrated spanner
    AGE LEVEL :14 and up
    SKILL LEVEL :beginner
    BUILD TIME :1 hour
    Model Scale 1/10
    Length 472mm / 18.5in
    Width 350mm / 13.7in
    Height 198mm / 7.7in
    Weight (No Battery) 3610g / 127.3oz
    Wheelbase 295mm / 11.6in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis 4WD
    Drivetrain N/A
    Wheel Size (Diameter x Width) 128mm x 70mm
    Wheel Hex Size N/A
    Tire Tread 230mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 15.22:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor TORX10L Brushless Motor Kv2850
    Battery 4x AA alkaline and 1x 7.4V 4000-5000mAh LiPo battery (required)
    Servos N/A
    Radio Syncro KT–232P transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
