Official Roc Hobby Mashigan 1/10 Scale 4WD Crawler RTR Thread
    • 8228
    Mashigan Red 1/10 Scale 4WD Crawler - RTR from FMS - FMS11033RSRD
    Click image for larger version  Name:	master.jpg Views:	0 Size:	156.8 KB ID:	362491
    Version Info: This vehicle is delivered as “RTR” but requires the additional purchase of 4 (four) AA alkaline batteries for the transmitter and 2S or 3S LiPo battery (see requires below).
    Motion RC is pleased to offer an outstanding 1/10 scale crawler from Roc Hobby, the Mashigan. Incorporating a traditional four-link suspension system with metal trapezoidal beams for strength and durability, the Mashigan rides confidently on high-grip 1.9” crawler tires with oil-filled, coil-over dampers. A powerful 550-size, 35T brushed crawling motor delivers the torque required to confidently traverse most obstacles, while the impressively detailed, hard plastic body shell features LED lights, opening doors, removable top, retracting windscreen, and opening hood and tailgate. The impressive attention to detail remains evident in the detailed and realistic dashboard, instrument cluster, nylon roll cage, and soft-touch rubber seats.
    Simply add 4 AA batteries for the interference-free 2.4GHz transmitter, your choice of 2S or 3S LiPo battery and appropriate charger to begin your scale crawling adventure.
    Combine the versatile, go-anywhere fun of the Roc Hobby Mashigan Red 1/10 Scale 4WD Crawler with Motion RC’s industry-leading customer service and product support for a package that cannot be beat!
    Highly Detailed
    The Mashigan features a strong, injection-molded body shell with unsurpassed detail, while interior features and materials deliver impressive scale fidelity.
    Removable Roof
    Explore three options for your scale look: Roof and Cage, Cage only, or completely open.
    Impressive Interior
    In addition to the detailed dashboard and instrument cluster, the Mashigan also features a synchronized steering wheel that rotates proportionally to the front wheels. Add a 1/10 scale driver figure (not included) for additional realism!
    Metal Ladder Frame
    The solid metal frame rails offer a rugged platform to tackle the toughest terrain or obstacles.
    • Full-time 4WD, assembled and ready-to-run
    • Complete ball bearings
    • Detailed, injection-molded hard plastic body shell
    • Four-link suspension system
    • Realistic interior with soft rubber seats
    • Opening hood, side doors, and tailgate
    • Metal frame rails
    • 9 inch All-Terrain tires
    • Brushed 35T 550-size crawler motor
    • LED light set
    • Roc Hobby Mashigan Red 1/10 Scale 4WD Crawler - RTR
    • 4GHz Transmitter
    • 2-in-1 Receiver / 40A ESC (factory-installed)
    • 550 Brushed Motor (factory-installed)
    • 9g Plastic Digital Servo (factory-installed)
    • 15kg Metal Digital Steering Servo (factory-installed)
    • Product Manual
    Requires:
    • 4x AA Alkaline batteries for transmitter
    • 2S 5000mAh LiPo with XT60 connector (EPR53002X6) or 3S 5000mAh LiPo with XT60 connector (EPR53003X6)
    Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :beginner
    BUILD TIME :less than 15 minutes
    Model Scale 1/10
    Length 546mm / 21.4in
    Width 274mm / 10.7in
    Height 282mm / 11.1in
    Weight (No Battery) 3968g / 140oz
    Wheelbase 339mm / 13.3in
    Ground Clearance 82mm / 3.2in
    Body Injection molded ABS plastic, factory painted with clear windows
    Chassis Metal/Composite scale-type
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 115mm x 30mm
    Wheel Hex Size N/A
    Tire Tread All-Terrain
    Bushing Material N/A
    Suspension Four-link with dampers
    Shock Type Oil-filled, coil-over
    Transmission 4WD Shaft-driven
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential No
    Ball Bearings Yes
    Brakes Electronic
    Electronic Speed Control Brushed 2-in-1 RX/ESC (included)
    Motor 550-size brushed
    Battery 7.4V-11.1V LiPo (not included)
    Servos 2
    Radio 2 Channel
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time Less than 15 minutes
    Recommended Environment Indoors/Outdoors
