Official Diecast Masters 1/16 Scale Freightliner Cascadia Raised Roof Sleeper Cab Semi Truck Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
Name:	diecast-masters-1-16-scale-freightliner-cascadia-raised-roof-sleeper-cab-semi-truck-rtr-motion-rc-34455439671481.jpg
    Freightliner Cascadia semi tractors are widely used in transportation and construction. The Diecast Masters officially licensed 1/16 scale RC replica features an interference-free 2.4GHz radio system with digital proportional throttle operation in forward and reverse, steering, and operational lock/unlock of the fifth-wheel kingpin via the transmitter. Functional headlights, taillights, cab markers, turn signals, backup lamps, and realistic sound system combine to result in an amazingly realistic replica suitable for display or operation. Use this tractor with Diecast Masters 1/16 scale XL 120 Trailer (DCM27008) for a truly impressive 1/16 scale tractor/trailer rig!
    Combine this incredible diecast operating replica with Motion RC’s industry-leading customer service and product support for a package that cannot be beat!
    Realistic 5th Wheel Operation
    The DC Freightliner Cascadia includes an operational 5th wheel and includes connectors for use with DC27008 trailer.
    Complete Package
    The Freightliner Cascadia contains all necessary components with nothing else to buy! Install transmitter batteries, charge the drive battery, and the open road is yours.
    • Officially licensed by Daimler Trucks North America, LLC
    • Fully functioned digital proportional 2.4GHz radio control system
    • Complete LED light and sound system
    • Functional 5th wheel with included connectors for DCM27008 trailer
    • Includes 7.4V 2000mAh rechargeable lithium battery and convenient USB charger
    • Diecast Masters 1/16 Scale Freightliner Cascadia Raised Roof Sleeper Cab Semi Truck - RTR
    • 2.4 GHz Transmitter
    • 7.4V 2000mAh Rechargeable LiPo Battery Pack
    • USB Charger
    • 2x AA alkaline batteries for the transmitter
    • Instruction manual
    Requires:
    • Nothing, everything is included
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 15 Minutes
    Scale 1/16
    Length 584mm / 23"
    Width 203mm / 8"
    Height 262mm / 10.3"
    Weight 2,200g / 102.4oz
    Wheelbase N/A
    Ground Clearance N/A
    Body Factory painted and decorated
    Chassis Plastic/Metal
    Drivetrain 2WD
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material Metal
    Suspension N/A
    Shock Type N/A
    Transmission Metal-geared
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings Yes
    Brakes Electronic
    Electronic Speed Control Forward/Reverse
    Motor Brushed
    Battery 2S LiPo (included)
    Servos N/A
    Radio Multi-Channel (included)
    Lights Yes
    Sound Yes
    Water Resistant No
    Skill Level Beginner
    Assembly Time Less Than 15 Minutes
