This is for all of the Hobby Plus 1/24 scale Micro Crawlers. The CR24 G-Armor is used as an example, as most of the differences are cosmetic.
Version Info: This vehicle is delivered as “RTR” but requires the additional purchase of 4 (four) AAA alkaline batteries for the transmitter, sold separately (see Requires below for details).
The Hobby Plus brand of crawlers deliver all the features, performance, and handling you’ve come to expect at a budget-friendly price you won’t. Don’t let the compact size fool you, this micro crawler has features that defy its size, such as FPV-ready electronics, CMS (chassis-mounted servo system), hi-torque 3-wire micro servo, and included LiPo battery and USB charger.
The drivetrain features an innovative gearbox that delivers massive torque at low RPM for a finely controlled micro crawling experience. The combination of waterproof electronics and LiPo power deliver over 40 minutes of runtime per charge, while internal beadlock wheels secure a soft-compound tire for impressive grip on a wide variety of surfaces and obstacles. The detailed G-Armor body features a molded plastic grille with light buckets, roof rack with light buckets, snorkel, side mirrors and spare tire to provide an impressive scale appearance while still offering personalized custom touches.
Enjoy an impressively realistic micro-crawling experience by combining the versatile, go-anywhere fun of Hobby Plus Crawlers with Motion RC’s parts and technical support, industry-leading customer service and product assortment for a package that cannot be beat!
AGE LEVEL : 14 and up
SKILL LEVEL : Beginner
BUILD TIME : None
CR24 Blue G-Armor 1/24 Scale 4WD Micro Crawler - RTR from Hobby Plus - HBP2410128-BL
Durable Design Metal chassis rails anchor a proven link-style suspension for maximum articulation and grip. |
2S Lipo Power The included LiPo battery delivers an impressive 40 minutes of runtime per charge. |
Impressive Electronics The CR24 Electronic package includes a 3-wire, chassis mounted servo and reliable 2.4GHz receiver with FPV and auxiliary LED power ports. |
2.4GHz Radio Reliability The comfortable transmitter offers all of the electronic setting options to customize the mini crawling experience to your specific requirements. |
- Aluminum anodized ladder frame chassis
- Chassis mounted 3-wire servo
- Highly detailed body with included scale accessories
- Front grille with headlight mounts
- Four piece spotlight mounts
- Functional spare tire
- Front and Rear LED light set included
- High torque transmission gear box
- 2S 7.4v 360mAh LiPo battery
- USB charger
- Super-soft tires
- Internal beadlock wheels
- Waterproof electronics
- FPV Ready ESC
- Additional RX power port for additional lights or FPV
- Hobby Plus CR24 Blue G-Armor 1/24 Scale 4WD Micro Crawler - RTR
- Hobby Plus 2.4GHz transmitter
- 2S 7.4v 600mAh LiPo battery
- USB charger
- Instruction Manual
- 4x AAA Alkaline batteries for transmitter
BUILD TIME : None
| Model Scale | 1/24 |
| Length | 215mm / 8.4in |
| Width | 104mm / 4.1in |
| Height | 106mm / 4.2in |
| Weight (No Battery) | 260g / 9.2oz |
| Wheelbase | 121mm / 4.7in |
| Ground Clearance | 27mm / 1.0in |
| Body | Polycarbonate, factory painted and decorated |
| Chassis | Composite with metal rails |
| Drivetrain | 4WD |
| Wheel Size (Diameter x Width) | 24.5mm x N/A |
| Wheel Hex Size | 7mm |
| Tire Tread | Multi-surface |
| Bushing Material | Oilite bronze |
| Suspension | 4-wheel, solid axle |
| Shock Type | Spring dampers |
| Transmission | N/A |
| Gear Pitch | MOD 0.3 |
| Internal Gear Ratio | 51.2:1 |
| Final Drive Ratio | 104:1 |
| Pinion | 12T |
| Spur Gear | 54T |
| Differential | No |
| Ball Bearings | No |
| Brakes | Electronic |
| Electronic Speed Control | 2-in-1 RX/ESC |
| Motor | Mini 030 brushed 55T |
| Battery | 2S 7.4v 600mAh LiPo |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | 3-wire, 1Kg waterproof |
| Radio | 2 Channel (included) |
| Lights | Yes |
| Sound | No |
| Water Resistant | Yes |
| Skill Level | Beginner |
| Assembly Time | None |
| Recommended Environment | Indoors/Outdoors |
.png)
