Official Hobby Plus Micro Crawler RTR Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    This is for all of the Hobby Plus 1/24 scale Micro Crawlers. The CR24 G-Armor is used as an example, as most of the differences are cosmetic.
    CR24 Blue G-Armor 1/24 Scale 4WD Micro Crawler - RTR from Hobby Plus - HBP2410128-BL
Name:	hobby-plus-cr24-blue-g-armor-1-24-scale-4wd-micro-crawler-rtr-motion-rc-34485107884217.jpg
    Version Info: This vehicle is delivered as “RTR” but requires the additional purchase of 4 (four) AAA alkaline batteries for the transmitter, sold separately (see Requires below for details).
    The Hobby Plus brand of crawlers deliver all the features, performance, and handling you’ve come to expect at a budget-friendly price you won’t. Don’t let the compact size fool you, this micro crawler has features that defy its size, such as FPV-ready electronics, CMS (chassis-mounted servo system), hi-torque 3-wire micro servo, and included LiPo battery and USB charger.
    The drivetrain features an innovative gearbox that delivers massive torque at low RPM for a finely controlled micro crawling experience. The combination of waterproof electronics and LiPo power deliver over 40 minutes of runtime per charge, while internal beadlock wheels secure a soft-compound tire for impressive grip on a wide variety of surfaces and obstacles. The detailed G-Armor body features a molded plastic grille with light buckets, roof rack with light buckets, snorkel, side mirrors and spare tire to provide an impressive scale appearance while still offering personalized custom touches.
    Enjoy an impressively realistic micro-crawling experience by combining the versatile, go-anywhere fun of Hobby Plus Crawlers with Motion RC’s parts and technical support, industry-leading customer service and product assortment for a package that cannot be beat!
    Durable Design
    Metal chassis rails anchor a proven link-style suspension for maximum articulation and grip.
    2S Lipo Power
    The included LiPo battery delivers an impressive 40 minutes of runtime per charge.
    Impressive Electronics
    The CR24 Electronic package includes a 3-wire, chassis mounted servo and reliable 2.4GHz receiver with FPV and auxiliary LED power ports.
    2.4GHz Radio Reliability
    The comfortable transmitter offers all of the electronic setting options to customize the mini crawling experience to your specific requirements.
    Features:
    • Aluminum anodized ladder frame chassis
    • Chassis mounted 3-wire servo
    • Highly detailed body with included scale accessories
    • Front grille with headlight mounts
    • Four piece spotlight mounts
    • Functional spare tire
    • Front and Rear LED light set included
    • High torque transmission gear box
    • 2S 7.4v 360mAh LiPo battery
    • USB charger
    • Super-soft tires
    • Internal beadlock wheels
    • Waterproof electronics
    • FPV Ready ESC
    • Additional RX power port for additional lights or FPV
    Includes:
    • Hobby Plus CR24 Blue G-Armor 1/24 Scale 4WD Micro Crawler - RTR
    • Hobby Plus 2.4GHz transmitter
    • 2S 7.4v 600mAh LiPo battery
    • USB charger
    • Instruction Manual
    Requires:
    • 4x AAA Alkaline batteries for transmitter
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/24
    Length 215mm / 8.4in
    Width 104mm / 4.1in
    Height 106mm / 4.2in
    Weight (No Battery) 260g / 9.2oz
    Wheelbase 121mm / 4.7in
    Ground Clearance 27mm / 1.0in
    Body Polycarbonate, factory painted and decorated
    Chassis Composite with metal rails
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 24.5mm x N/A
    Wheel Hex Size 7mm
    Tire Tread Multi-surface
    Bushing Material Oilite bronze
    Suspension 4-wheel, solid axle
    Shock Type Spring dampers
    Transmission N/A
    Gear Pitch MOD 0.3
    Internal Gear Ratio 51.2:1
    Final Drive Ratio 104:1
    Pinion 12T
    Spur Gear 54T
    Differential No
    Ball Bearings No
    Brakes Electronic
    Electronic Speed Control 2-in-1 RX/ESC
    Motor Mini 030 brushed 55T
    Battery 2S 7.4v 600mAh LiPo
    Servos 3-wire, 1Kg waterproof
    Radio 2 Channel (included)
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Indoors/Outdoors
