Official Tamiya MAN TGX 26.540 6x4 XLX 1/14 Scale Tractor Truck Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Click image for larger version  Name:	tamiya-man-tgx-26-540-6x4-1-14-scale-rc-tractor-truck-kit-motion-rc-34548352188601.jpg Views:	0 Size:	90.0 KB ID:	375599
    Click image for larger version  Name:	tamiya-man-tgx-26-540-6x4-xlx-light-metallic-blue-1-14-scale-rc-tractor-truck-kit-motion-rc-34548415168697.jpg Views:	0 Size:	92.5 KB ID:	375600
    Version Info: This truck is a KIT. Assembly and painting is required. A plain white cab comes out of the box ready for paint. Photos show a completed and painted model. The Light Blue MEtallic truck comes pre-painted. Minimum 4+ channel radio system, ESC, battery, charger and servos will need to be purchased separately.
    Experience the realism of this expertly engineered model. An impressive representation of its real-life counterpart, which won the 2008 Truck of the Year award. Its two rear axles help it easily handle heavy loads over long distances, while its 12.4 liter turbocharged diesel engine meets the Euro 5 emissions standards for greater environmental conscientiousness. This award winning truck comes reproduced as a 1/14 scale electric RC model. The model boasts an impressive balance of style and performance with a detailed ladder frame chassis, aluminum channels, suspension with metal leaf springs, friction dampers, and differentials for realistic movement. The model's two different metal plating and metal transfers provide a true-to-scale finish, while the 3-speed transmission allows gear shifting during operation. Enhance your experience with the separately available MFC-01 or MRC-03 unit for sound and lighting actions.
    Your Tamiya truck is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    540-Sized Motor and 3-Speed Transmission
    The 540-sized brushed motor applies power through a selectable 3-speed transmission to drive dual rear axles.
    Exceptional Scale Detail
    Scale details surround this truck for exceptional realism.
    Dual Rear Axles
    Each axle is supported with leaf spring and shocks.
    Optional Light and Sound
    Add your own light and sound package with the separately-sold Multi-Function Control Unit MFC-01.
    1/14 Scale
    This truck comes in an impressive 1/14 scale. Coming in at close to 2 feet in length, it has an ideal on-road presence while being convenient to transport.
    Add Your Own Electronics and Drive!
    Once you add your preferred electronics you're ready for those on-road adventures.
    • Exceptional scale detail and realism brings this truck to life on every level
    • Includes a powerful 540-sized brushed motor driven by a 3-speed transmission
    • Dual rear axles each supported with leaf spring and shocks
    • Cab comes out of the box white so you can paint your chosen custom scheme
    • The ladder frame chassis features aluminum channels, suspension with metal leaf springs and friction dampers, and rear axles are equipped with differentials
    • Just like the actual vehicle, this model comes with large-sized curved side mirrors that feature two mirror surfaces
    • Metal-plated parts are included to depict the MAN EURO 5 engraving and right/left step plates
    • Metal transfers also recreate the MAN logo/Lion emblem on the front grille and TGX 26.540 logos on both doors respectively
    • Tamiya MAN TGX 26.540 6x4 XLX 1/14 Scale RC Tractor Truck - KIT
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 3+ hours
    Model Scale 1/14
    Length 526mm / 20.7in
    Width 193mm / 7.6in
    Height 301mm / 11.9in
    Weight (No Battery) 3800g / 134oz
    Wheelbase 440mm / 17.3in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis Aluminum and ABS Plastic
    Drivetrain 2WD
    Wheel Size (Diameter x Width) 83mm x 22mm
    Wheel Hex Size N/A
    Tire Tread Front: 156mm / Rear: 138mm
    Bushing Material Metal and Plastic
    Suspension Leaf Spring
    Shock Type Friction Damper
    Transmission 3-Speed
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio 1st gear 32.49:1, 2nd gear 17.76:1, 3rd gear 10.66:1
    Pinion N/A
    Spur Gear N/A
    Differential Gear
    Ball Bearings N/A
    Brakes Electronic
    Electronic Speed Control 6 Cell 7.2V NiMH Brushed ESC (required)
    Motor 540-Brushed
    Battery 7.2V 1600mAh (required)
    Servos 2x standard size (required)
    Radio 4+ Channel (required)
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 3+ Hours
    Recommended Environment On-road, smooth, paved surfaces
  • taz101
    ɹǝʎlℲ ǝᴉssn∀
    • Dec 2017
    • 27
    • ɐᴉlɐɹʇsn∀
    Didnt you like the other thread you started on this truck?
    • WilliamJames
      • Jun 2023
      It's good - but not the current model? Take a look at the ones that are being sold now with the rear view mirror cameras: https://www.truckpages.co.uk/news/ma...s-not-mirrors/ This one is like the older used MAN TGX for sale
