Official Team Corally Punisher4 4S 1/8 Scale 4WD Monster Truck Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Version Info: Fully assembled, decorated, and ready-to-run, this model requires one 2S, 3S, or 4S LiPo battery with XT90 connector, a suitable charger, and 4 AA alkaline batteries for the transmitter.
    Introducing the Team Corally Punisher4, a cutting-edge 1/8 scale monster truck built to redefine off-road bashing. Designed for RC enthusiasts of all skill levels, the Punisher4 seamlessly blends power, durability, and innovation, delivering an electrifying experience for both newcomers and seasoned bashers. Built on the proven Syncro4 platform, this monster truck offers an unbeatable combination of performance and reliability, straight out of the box. With its aggressive stance and the iconic Punisher body, this truck brings legendary toughness to scale, ensuring you stand out on any terrain.
    At the heart of the Punisher4 is a Kuron 725 4-pole, 2150kv sensorless brushless motor, paired with the high-performance Torox 135 Electronic Speed Control. Together, they unleash blistering speeds of over 75 km/h when powered by 4S LiPo batteries, guaranteeing thrilling acceleration and top-tier performance. Precision handling is ensured by the HV7225 digital high-speed servo, featuring robust metal gears and 25Kg of torque, allowing for effortless control in the most demanding conditions. To complement its raw power, the CT2S compact 2.4 GHz transmitter provides ultra-responsive control with a range exceeding 200 meters. Key features such as steering dual rate, servo reverse, and a 50%-100% power switch make the Punisher4 adaptable for drivers of all skill levels while ensuring smooth and precise maneuverability.
    Designed to conquer any terrain, the Punisher4’s advanced suspension system borrows the best elements from the Radix6 and Sketer, incorporating heavy-duty wide steering blocks, rear hubs, composite towers, and 4mm CNC-machined arm holders for unparalleled durability. Its big bore composite shocks provide exceptional damping, allowing the truck to absorb impact effortlessly and remain stable over jumps, rocky paths, or loose dirt tracks. The reinforced drivetrain features a 52T spur gear, steel outdrive cups, central driveshafts, and aerospace-quality rubber-sealed ball bearings, ensuring maximum efficiency and durability for long-lasting, high-performance action. Paired with wide hubs and Sketer’s Multi-Block Stunt Tyres (134x70mm), the Punisher4 delivers outstanding grip, control, and stability across all surfaces.
    While the Punisher4 is race-ready out of the box, Team Corally offers a wide selection of tuning parts, allowing enthusiasts to fine-tune performance to their preferences. Its lightweight construction, high-speed agility, and responsive handling make every drive an exhilarating experience, whether you're tearing through dirt trails or performing high-flying stunts. More than just a monster truck, the Punisher4 sets a new benchmark in the RC world, merging the agility of a buggy with the sheer power of a monster truck. Its rugged design, cutting-edge technology, and next-level durability make it the ultimate choice for off-road RC enthusiasts looking to push the limits of performance and fun.
    Durable Body in 3 Vibrant Colors
    Redesigned for a sleek and flowing profile, this fully painted body is not only a visual treat but also a performance enhancer featuring new roof skids. Choose from three vibrant colors – red, blue and green. Prioritizing convenience without compromise, securing the body clips with reliable clip retainers.
    Scorpion XTB MX-type Tires on 11-Spoke Rims
    The Punisher4 maintains maximum grip, acceleration, and stability thanks to its ADT (arrow directional tread) design, well known from the Sketer. This multi-purpose tire is well-suited for a wide range of surfaces, from soft, loamy dirt or sand to concrete or tarmac. Bash on!
    Heavy-Duty Steering Blocks
    Drawing inspiration from the esteemed 6S lineup, the Team Corally Punisher4 features composite steering knuckles that redefine precision. These steering blocks enhance the fit and security of the pillow balls, eliminating the risk of dislodging during rough landings or collisions.
    Aerodynamic Flex Wing
    This new cutting-edge wing brings increased flexibility compared to its predecessor, guaranteeing top-notch performance in diverse conditions. The bold design not only enhances aesthetics but also maximizes downforce, delivering exceptional stability during high-speed runs and jumps.
    Big Bore Composite Shock Absorbers
    16mm shocks on the Team Corally Punisher4 – merging affordability with superior performance. First seen on the Syncro4 and now a staple in the Punisher4, these shocks have set a new benchmark. Constructed from robust composite material and complemented by a composite/aluminum top, they provide exceptional durability. These shocks retain key components such as 4mm tuned pistons, precision shafts, and medium springs, allowing them to adapt seamlessly to various bashing styles with different fluids for all conditions. Enhanced lower shock ends boost durability, ensuring smooth performance even during the toughest stunts.
    Aluminium Chassis with Side Guards and Skid
    The Team Corally Punisher4 features the same robust aluminum 3mm chassis as the Syncro4, now showcasing a new engraving for added flair. This chassis not only provides exceptional durability but also adds a touch of style to your off-road adventures. The side guards have been redesigned to be much taller, effectively keeping dirt and debris out. Additionally, it features skid plates known from the Kagama, forming a tough protective shield for internal components.
    Hybrid Chassis Brace System
    The Punisher4 utilizes composite braces secured to the chassis braces and central differential. The rear brace is designed with a dedicated space for a GPS and fan mount, offering added customization options for bashers looking to track their speed and add extra cooling. It also has a robust 4mm aluminum upper suspension arms mount that doubles as a mounting point for the brace.
    Extra Large Battery Compartment
    Designed to accommodate a wide range of LiPo pack setups, the tray supports battery sizes up to 51x161mm, with a maximum height of 58mm. The Punisher4 inherits the Kagama's legacy, offering a spacious battery tray that ensures compatibility and convenience. Included Velcro straps, engineered for a snug and secure fit, simplify battery changes, making transitions from a 3S to a 4S setup straightforward and effortless.
    • Speeds of up to 75+ km/h (45+ MPH) are possible
    • Pre-built Ready to Run XL4S monster truck
    • Team Corally TOROX 135 ESC 2-4S with LiPo protection
    • Team Corally Kuron 725 2150kV 4-pole brushless motor
    • CRHV-7225 HV metal gear 25Kg torque steering servo
    • Team Corally CT2S new 2.4GHz transmitter with 50/100% power switch
    • Aluminium servo arm
    • One-piece composite steering link
    • New splash-proof and dustproof electronic box with transponder mount
    • Extra large adjustable battery holder for all common LiPo batteries
    • Full set of ball bearings, rubber sealed
    • All transmission ball bearings are 8x16x5mm
    • Steel spur gear and motor pinion
    • Three sealed differentials individually filled with silicone oil
    • Quick and easy diff access
    • Aluminium motor holder with spur gear cover
    • Fixed motor position for 13T, 15T and 17T pinion
    • 52T steel central gear
    • Ultra-rigid composite chassis brace system
    • Performance data logger holder
    • Complete hard coated steel outdrives
    • Extra surface hardened steel front CVD joints
    • Aluminium 17mm drive hexes
    • Oil-filled threaded 16 mm plastic big bore shocks
    • Shock spring perches locking system
    • Nylon composite shock cap protectors
    • Composite front and rear shock towers
    • Independent pivot ball front suspension
    • Independent double wishbone rear suspension
    • Optimized, custom developed composite parts
    • Wide HD front steering blocks and rear hubs
    • Thick 4mm aluminium suspension pin braces
    • Composite suspension braces protectors
    • Heavy-duty one-piece composite suspension links and tie rods
    • 3mm aluminium laser etched chassis plate
    • Tall, reinforced chassis side guards with integrated body protection
    • Heavy duty front bumper
    • New reinforced high downforce wing
    • Factory-mounted and glued bash-ready tyres on black 7-spoke composite wheels
    • Sturdy, elaborately printed polycarbonate body available in 3 color schemes
    • Iconic punisher body
    • Body roof protector/support
    • Adjustable body mounts
    • Heavy-duty wheelie bar
    • Serrated wheel nuts
    • Wide assortment of tuning parts available for individual customization
    • Team Corally Punisher4 4S Blue 1/8 Scale 4WD Monster Truck - RTR
    • Custom painted body
    • Team Corally CT2S 2.4GHz transmitter with 50%/100% power switch
    • Team Corally Kuron 725 2150Kv 4-pole brushless motor 2-4S
    • Team Corally TOROX 135 ESC 2-4S with LiPo protection (programmable)
    • Varloprop CRHV-7225 HV metal gear 25Kg torque steering servo
    • Adjustable battery holder for all common LiPo batteries
    • Instruction manual
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : None
    Model Scale 1/8
    Length 505mm / 19.8in
    Width 393mm / 15.4in
    Height 190mm / 7.4in
    Weight (No Battery) 4250g / 149.9oz
    Wheelbase 327mm / 12.8in
    Ground Clearance 67mm / 2.6in
    Body Polycarbonate
    Chassis Aluminum with composite side guards
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 134mm x 70mm
    Wheel Hex Size 17mm
    Tire Tread Offroad
    Bushing Material Ball bearing
    Suspension Independent
    Shock Type Oil-filled big bore
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 13.23 (MOD.1)
    Final Drive Ratio N/A
    Pinion 13T, 15T, 17T
    Spur Gear 52T
    Differential Oil-filled
    Ball Bearings Full, rubber sealed
    Brakes Electronic
    Electronic Speed Control TOROX 135
    Motor Kuron 725 2150kV 4-pole brushless motor
    Battery 2S - 4S LiPo with XT90 connector (required)
    Max Battery Dimensions (L x W x H) 51 x 161 x 58mm (2 x 6.3 x 2.2in)
    Servos CRHV-7225 HV metal gear 25Kg torque steering servo
    Radio CT2S 2.4GHz transmitter
    Lights No
    Sound No
    Water Resistant Splash-proof
    Skill Level Intermediate
    Assembly Time None
