Official Team Corally Kagama4 4S 1/8 Scale 4WD Monster Truck Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Version Info: Fully assembled, decorated, and ready-to-run, this model requires one 2S, 3S, or 4S LiPo battery with XT90 connector, a suitable charger, and 4 AA alkaline batteries for the transmitter.
    Introducing the Team Corally Kagama4, the ultimate XL4S scale monster truck engineered for off-road dominance. Designed for both seasoned bashers and newcomers alike, the Kagama4 blends strength, durability, and advanced technology into a compact, high-performance package. Built on the proven Syncro4 platform, this truck delivers an unparalleled bashing experience straight from the factory—no modifications required. Team Corally has taken the concept of “truggified” performance to new heights, offering enthusiasts the perfect fusion of power, precision, and rugged durability.
    At the heart of the Kagama4 is the Kuron 725 4-pole, 2150kv sensorless brushless motor, working in tandem with the Torox 135 Electronic Speed Control to unleash exhilarating power. Fueled by 4S LiPo batteries, this powerhouse is capable of reaching speeds over 75 km/h, ensuring every run is packed with adrenaline-pumping excitement. Precision handling is guaranteed by the HV7225 digital high-speed servo, featuring durable metal gears and 25Kg of torque, giving you superior control over any terrain. Paired with the CT2S compact 2.4 GHz transmitter, the Kagama4 offers lightning-fast response times, a range exceeding 200 meters, and essential adjustments like steering dual rate, servo reverse, and a 50%-100% power switch, making it accessible for all skill levels.
    Engineered to master the toughest landscapes, the Kagama4’s advanced suspension system draws inspiration from the Radix6 and Sketer, incorporating wide steering blocks, rear hubs, composite towers, and 4mm CNC-machined arm holders for exceptional durability. Heavy-duty composite big bore shocks absorb impact with ease, ensuring stability and control whether you're tackling dirt tracks, rocky trails, or stunt ramps. The robust drivetrain features a 52T spur gear, steel outdrive cups, central driveshafts, and aerospace-quality rubber-sealed ball bearings, optimizing efficiency and durability for relentless performance. With wide hubs and Sketer’s Multi-Block Stunt Tyres (134x70mm), the Kagama4 delivers outstanding grip and stability on any surface.
    Beyond raw power, the Kagama4 is designed for customization and tuning, allowing enthusiasts to fine-tune its performance to match their driving style. Lightweight construction and agile handling make it incredibly responsive out of the box, but for those looking to push limits even further, Team Corally offers a wide array of performance upgrades. More than just a truck, the Kagama4 sets a new standard in the bashing community, seamlessly blending the agility of a buggy with the sheer power of a monster truck. Its aggressive design, rugged durability, and high-performance engineering make it the ultimate choice for RC enthusiasts seeking the next level of off-road excitement.
    Durable Body in 3 Vibrant Colors
    Redesigned for a sleek and flowing profile, this fully painted body is not only a visual treat but also a performance enhancer featuring new roof skids. Choose from three vibrant colors – red, blue and green. We prioritize convenience without compromise, securing the body clips with reliable clip retainers.
    High-Performance Wheelie Bar
    The Kagama4 comes standard with a durable wheelie bar featuring an oversized mono-wheel design supported by large ball bearings with nylon composite frame members.
    Aerodynamic Flex Wing
    This new cutting-edge wing brings increased flexibility compared to its predecessor, guaranteeing top-notch performance in diverse conditions. The bold design not only enhances aesthetics but also maximizes downforce, delivering exceptional stability during high-speed runs and jumps.
    Scorpion XTB MX-type Tires on 11-Spoke Rims
    The Kagama4 maintains maximum grip, acceleration, and stability thanks to its ADT (arrow directional tread) design, well known from the Sketer. This multi-purpose tire is well-suited for a wide range of surfaces, from soft, loamy dirt or sand to concrete or tarmac. Bash on!
    Big Bore Composite Shock Absorbers
    16mm shocks on the Team Corally Kagama4 – merging affordability with superior performance. First seen on the Syncro4 and now a staple in the Kagama4, these shocks have set a new benchmark. Constructed from robust composite material and complemented by a composite/aluminum top, they provide exceptional durability. These shocks retain key components such as 4mm tuned pistons, precision shafts, and medium springs, allowing them to adapt seamlessly to various bashing styles with different fluids for all conditions. Enhanced lower shock ends boost durability, ensuring smooth performance even during the toughest stunts.
    Aluminium Chassis with Side Guards and Skid
    The Team Corally Kagama4 features the same robust aluminum 3mm chassis as the Syncro4, now showcasing a new engraving for added flair. This chassis not only provides exceptional durability but also adds a touch of style to your off-road adventures. The side guards have been redesigned to be much taller, effectively keeping dirt and debris out. Additionally, it features skid plates known from the Kagama, forming a tough protective shield for internal components.
    Precision Drivetrain with 3 Oil-Filled Differentials
    The Team Corally Kagama4 features a robust drivetrain specifically optimized for 4S power systems. Steel outdrive cups seamlessly connect to steel central driveshafts, ensuring exceptional strength and longevity. The front end is driven by CVD driveshafts for precise propulsion, while the rear utilizes durable metal dogbones, providing a dynamic and reliable performance. The entire drivetrain is enhanced with aerospace-quality 8x16x5mm rubber-sealed ball bearings, maximizing precision, efficiency, and durability.
    Extra Large Battery Compartment
    Designed to accommodate a wide range of LiPo pack setups, the tray supports battery sizes up to 51x161mm, with a maximum height of 58mm. The Kagama4 inherits the Kagama's legacy, offering a spacious battery tray that ensures compatibility and convenience. Included Velcro straps, engineered for a snug and secure fit, simplify battery changes, making transitions from a 3S to a 4S setup straightforward and effortless.
    • Speeds of up to 75+ km/h (45+ MPH) are possible
    • Pre-built Ready to Run XL4S monster truck
    • Team Corally TOROX 135 ESC 2-4S with LiPo protection
    • Team Corally Kuron 725 2150kV 4-pole brushless motor
    • CRHV-7225 HV metal gear 25Kg torque steering servo
    • Team Corally CT2S new 2.4GHz transmitter with 50/100% power switch
    • Aluminium servo arm
    • One-piece composite steering link
    • New splash-proof and dustproof electronic box with transponder mount
    • Extra large adjustable battery holder for all common LiPo batteries
    • Full set of ball bearings, rubber sealed
    • All transmission ball bearings are 8x16x5mm
    • Steel spur gear and motor pinion
    • Three sealed differentials individually filled with silicone oil
    • Quick and easy diff access
    • Aluminium motor holder with spur gear cover
    • Fixed motor position for 13T, 15T and 17T pinion
    • 52T steel central gear
    • Ultra-rigid composite chassis brace system
    • Performance data logger holder
    • Complete hard coated steel outdrives
    • Extra surface hardened steel front CVD joints
    • Aluminium 17mm drive hexes
    • Oil-filled threaded 16 mm plastic big bore shocks
    • Shock spring perches locking system
    • Nylon composite shock cap protectors
    • Composite front and rear shock towers
    • Independent pivot ball front suspension
    • Independent double wishbone rear suspension
    • Optimized, custom developed composite parts
    • Wide HD front steering blocks and rear hubs
    • Thick 4mm aluminium suspension pin braces
    • Composite suspension braces protectors
    • Heavy-duty one-piece composite suspension links and tie rods
    • 3mm aluminium laser etched chassis plate
    • Tall, reinforced chassis side guards with integrated body protection
    • Heavy duty front bumper
    • New reinforced high downforce wing
    • Factory-mounted and glued bash-ready tyres on black 7-spoke composite wheels
    • Sturdy, elaborately printed polycarbonate body available in 3 color schemes
    • Kagama style body
    • Body roof protector/support
    • Adjustable body mounts
    • Heavy-duty wheelie bar
    • Serrated wheel nuts
    • Wide assortment of tuning parts available for individual customization
    • Team Corally Kagama4 4S Blue 1/8 Scale 4WD Monster Truck - RTR
    • Custom painted body
    • Team Corally CT2S 2.4GHz transmitter with 50%/100% power switch
    • Team Corally Kuron 725 2150Kv 4-pole brushless motor 2-4S
    • Team Corally TOROX 135 ESC 2-4S with LiPo protection (programmable)
    • Varloprop CRHV-7225 HV metal gear 25Kg torque steering servo
    • Adjustable battery holder for all common LiPo batteries
    • Instruction manual
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : None
    Model Scale 1/8
    Length 505mm / 19.8in
    Width 393mm / 15.4in
    Height 190mm / 7.4in
    Weight (No Battery) 4250g / 149.9oz
    Wheelbase 327mm / 12.8in
    Ground Clearance 67mm / 2.6in
    Body Polycarbonate
    Chassis Aluminum with composite side guards
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 134mm x 70mm
    Wheel Hex Size 17mm
    Tire Tread Offroad
    Bushing Material Ball bearing
    Suspension Independent
    Shock Type Oil-filled big bore
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 13.23 (MOD.1)
    Final Drive Ratio N/A
    Pinion 13T, 15T, 17T
    Spur Gear 52T
    Differential Oil-filled
    Ball Bearings Full, rubber sealed
    Brakes Electronic
    Electronic Speed Control TOROX 135
    Motor Kuron 725 2150kV 4-pole brushless motor
    Battery 2S - 4S LiPo with XT90 connector (required)
    Max Battery Dimensions (L x W x H) 51 x 161 x 58mm (2 x 6.3 x 2.2in)
    Servos CRHV-7225 HV metal gear 25Kg torque steering servo
    Radio CT2S 2.4GHz transmitter
    Lights No
    Sound No
    Water Resistant Splash-proof
    Skill Level Intermediate
    Assembly Time None
