Official Primus Primus PC10 Pro D110 1/10 Scale 4WD Crawler Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Click image for larger version  Name:	69aa1660_primus-pc10-pro-d110-silver-1-10-scale-4wd-crawler-rtr.webp Views:	0 Size:	85.7 KB ID:	445403
    Click image for larger version  Name:	69aa1660_primus-pc10-pro-d110-orange-1-10-scale-4wd-crawler-rtr.webp Views:	0 Size:	84.7 KB ID:	445404
    Version Info: Fully assembled, decorated, and ready-to-run, this model requires a 1000-5000mAh 7.4V 2S LiPo battery with T connector and 4 AA alkaline batteries for the transmitter.
    Now available from Motion RC, the affordable yet supremely featured Primus PC10 Pro 1/10 scale crawler will surprise you with its looks and performance! Outfitted with independently locked or open front and rear differentials, the PC10 Pro can successively traverse the toughest climb or torque through a narrow crevasse. Metal-geared portal axles deliver increased torque, improve approach and descent angles and deliver ideal wheel speed for a superior crawling experience, while the shift-on-the-fly 2-speed transmission delivers climbing torque or top speed. The realistic molded plastic body, fender guards, and accessories combine to make this model not only a stunning display piece, but a credible, performance-oriented crawler. The included LED light set brings the realism of this replica to new levels while the powerful, water-resistant 750 brushed motor, Hobbywing 60A Crawler ESC, and bearing-equipped drivetrain deliver a reliable and enjoyable crawling experience.
    Elevate your crawling game by combining the versatile, durable, capable crawling performance of the Primus PC10 Pro 1/10 Scale 4WD Crawler with Motion RC’s industry-leading customer service, product selection, and complete parts support for a package that cannot be beat!
    Durable Drivetrain and Robust Undercarriage
    The well-appointed chassis features machined aluminum rails, while the fender guards, bumpers, and side guards combine to keep equipment dry and free from dirt and debris.
    Plush Suspension
    The Primus PC10 Pro crawler features aluminum, oil filled, coil-over shocks with preload adjusters for compliant handling.
    LED Lights
    The factory installed LED lighting system modes are selectable via the transmitter, allowing for turn signals, hazard flashers, headlight brightness and more.
    Intelligent Equipment Layout
    The PC10 Pro features an organized and neat equipment layout, while the generously sized battery compartment allow for a wide range of battery capacities.
    Comfortable, Reliable Radio System
    The 2.4GHz radio system delivers interference-free performance and useful adjustments to dial-in the crawler exactly the way you prefer!
    Maximum Grip
    The 42 x 116mm ultra-performance crawling tires are mounted on decorative beadlock wheels for enhanced adhesion on a wide array of surfaces and soils.
    Complete Package
    The 1/10 scale Primus PC10 Pro D110 RTR arrives assembled and ready to run. Install your choice of 2S Lipo, add 4 AA alkaline transmitter batteries and prepare yourself for an exhilarating crawling experience!
    Detailed Interior
    A fully detailed interior elevates scale realism and easily accepts a wide variety of optional 1/10 scale driver and passenger figures.
    • Portal axles for additional ground clearance and optimized wheel speed
    • Molded plastic body with opening doors and detailed interior
    • Independently lockable (from transmitter) front and rear differentials
    • Hobbywing 60A brushed crawler ESC, capable of both LiPo and NiMH operation
    • Model arrives fully decorated and ready to run
    • Shift-on-the-fly 2-speed transmission
    • LED light system, selectable from the transmitter
    • Proven four-link chassis design with aluminum main rails and adjustable aluminum, oil-filled, coil-over shocks
    • Shaft-driven 4WD system
    • Robust chassis links and tie rods for exceptional durability
    • Reliable and responsive 2.4GHz radio gear
    • 750 brushed crawler motor
    • Complete ball bearings
    • Accepts a wide range of battery packs for convenience and flexibility
    • Unique steering damper improves precision and reliability
    • Available in two attractive colors
    • Molded front and rear bumpers, fender guards, mirrors, and more!
    • High-grip crawler tires with functional bead lock wheels
    • Primus PC10 Pro D110 Silver 1/10 Scale 4WD Crawler - RTR
    • 2.4GHz transmitter
    • Quick start guide
    • Tools and spare parts
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 30 Minutes
    Model Scale 1/10
    Length 543mm / 21.2in
    Width 248mm / 9.7in
    Height 245mm / 9.5in
    Weight (No Battery) 3,500g / 125oz
    Wheelbase 313mm / 12.2in
    Ground Clearance 55mm / 2.1in
    Body Molded plastic composite
    Chassis Aluminum
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 116 x 42mm
    Wheel Hex Size 12mm
    Tire Tread All-terrain
    Bushing Material N/A
    Suspension Four-link with dampers, solid axles
    Shock Type Oil-filled, aluminum coil-ove
    Transmission Gear
    Gear Pitch M0.8
    Internal Gear Ratio 3.09:1
    Final Drive Ratio Lo 37:1, Hi 15:1
    Pinion 11T
    Spur Gear 34T
    Differential Open or locked
    Ball Bearings Complete
    Brakes Electronic
    Electronic Speed Control Hobbywing 60A with T connector
    Motor 750 brushed
    Battery 2S with T connector (required)
    Max Battery Dimensions (L x W x H) 140mm x 48mm x 30mm
    Servos
    • 1x Waterproof, metal gear, 15Kg
    • 3x 9Kg
    Radio 4-channel (included)
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time Less than 30 minutes
  • Roaming Gnome
    • Aug 2024
    • 141
    Had one for about a year now, it's a rebranded Yikong (according to the Yikong label on the frame), it's top heavy, the torque roll is ludicrous but with after market shocks and better tires and wheels, it makes a decent trail runner, I replaced the factory Dumborc radio with a Dumborc DDF-350 and P6DCG receiver, the gyro helps with the torque roll getting out of hand, eventually I'll mount the receiver in the bdy shell and extend sevo and esc leads with a magnetic contact strip so I fully wire the lights and still remove the shell
