Calibrating the sticks gets them so that the radio knows the full range of the physical sticks. That way when you put the stick in the middle of its range of motion, it's actually in the middle of it's range of motion as far as the gimble is concerned.
Building on that, before you level your blades at mid stick, you want to set your pitch curve so that it is 50% or 0 degrees at mid stick.
Then you can mechanically (or sub trim) your swash so that it actually is generating zero degrees pitch at mid stick. (Which is 50% your pitch curve, and your physical stick in the center of a calibrated gimble.)
It's a combination of multiple systems all aligning together.
Gimble/stick in the middle
Pitch curve is in the middle
Then swash adjusted to the middle.
This video example helped me understand this concept and all the pieces at play. The author of the video is working with a flybar head, which obviously the 110 doesn't have so that part is non essential, but the rest of the setup applies: https://www.youtube.com/watch?v=Br9YdUTDenQ
Actually, I just remembered. You mentioned having purchased John Salts ebooks. I have not seen them at all. Did you get the one about setting up the head? I'm really curious how he explains it.
Sorry if I'm confusing you. I'm not the best at explaining this stuff. Especially over text. I'm much more of a hands on type.
