500 size fuselages
  • 500 size fuselages
    Motion, please carry the ec135 in 500 size
    Would also be cool if they could work with Heli Roland to stock the Fenestron kit. As far as I know, they are only available through custom direct orders at the moment: http://www.rolandkraemer.de/index-Dateien/page0008.htm.
      +1
      More 500 size fuselage choices please
        Originally posted by seaviper View Post
        +1
        Completely agree. I personally find the 500 size to be a great balance between size, flight characteristics, and affordability. I have a wish list that is probably too long for my own good.. OH-58D, Bell 206, Bell 430, AH-1Z, Sikorsky R-5, OH-6A, UH-1H, UH-1Y, Dauphin, and Enstrom F-28 just to start :Drooling:.
          Right now I am looking at a HeliArtist UH-1 on ebay for belt tail. I wish we had a few more choices in the 500 department. I guess HeliArtist went Tango Uniform along with the rest of the scale mfg's.
          I would gladly settle for something in the 500 range WITH SKIDS that isn't a power egg. I like the eggs, especially the AH-6. But how about a nice two-bladed Huey or Cobra, or even a Bell 206 for heaven's sake. And I know the fuselages are very nice, but the price is a bit out there for the 600 size stuff.
          The 500 is just right in my humble opinion.
            I actually have the Heliartist UH-1 sitting around if you are interested. Started adding panel lines and such before I switched to working on my PKM UH-1C. If have the belt tail mechanism, as well as a set of scale blades for it.
              Looking forward to the UH-1. This will be my spring project. I'm planning a Navy Rescue scheme for it.
                Looking forward to seeing the build!
                  I am planning this scheme from HT-18.
                    Where can I go to find the scale bits like antennas, WSPS, etc?
                    • #11
                      I used finescale models for a lot of the detail parts on my Apache. Lots of detail parts for the Huey available here: https://www.fine-scalemodela.com/500-uh-1.html
                      • #12
                        I have a Raptor 50. It is nitro. It has a Redline 56H. Any suggestions for a good scale fuse from Motion?
                        • #13
                          Originally posted by Hardway View Post
                          I have a Raptor 50. It is nitro. It has a Redline 53. Any suggestions for a good scale fuse from Motion?
                          The raptor .50 equivalent to a 600 size heli, so it should be a pretty straight fit in any of the fuselages with a straight tail: https://www.motionrc.com/collections...%20to%201499mm. In particular, I would recommend either the Airwolf or an MD500. You will need to do some modification for an exhaust exit, and mounting the mechanics, but everything should be the right size.
                          • #14
                            Thanks! Wasn’t sure on the size conversion to electric. Did you get any more info on the lost F-4?
                            • #15
                              I looked around the apartment complex, talked to neighbors, checked dumpsters for a box, and no joy. Called Motion and they are looking into it. Hopefully it was just a system screw up and the package is still on the truck or something.
                              • #16
                                Finally started building the UH-1 project. I plan to do some work on her this weekend while it's raining.
                                • #17
                                  Awesome, looking forward to seeing it, be sure to post some photos!
                                  • #18
                                    Make that two looking forward to seeing your build!!
                                    • #19
                                      +1
                                      This is what I have laying around in 500 size: https://www.ebay.com/itm/254056139975 , https://www.ebay.com/itm/254059652248
                                      • #20
                                        SOLD all my450 & 500Size fuselages except the G-JIVE MD500 which I'm gonna build and keep! Thanks guys!!!
