swp
  • putang
    • Jan 2019
    • 3
    swp
    can someone explain this to me Swp cyclic travel 8
    50-125, default setting: +80
    Set the Swp cyclic travel 8° if the menu value is activated so that the
    rotor blade located above the tail tube is as accurate as 8° by full rollover
    stroke. To do this, the field must be selected (highlighted field)
    so that the swashplate can be controlled and adjusted in direct mode
    when gyro gain is switched off. This is the only mode in which the
    travel can be set correctly.
    It is very important that the travel is set correctly. It plays a major role
    in terms of acquiring the correct gyro gain.
