GYRO
  • daehahnn
    • Jul 2019
    GYRO
    Good day… I have 2 600
    scale RC helis currently using an ICG
    360
    with a AR7000 RX, and a ICG
    400
    with
    AR6200 RX.
    The helis both have flybars
    and I'm using a DX9 TX. Can I replace my ICG gyros with the Tarot ZYXS2 3-Axis Flight Controller..? If so does the ZYXS2 replace the current RXs I'm using? Both ships are nitro also FYI. Thank you
  • ridgerunner
    • Nov 2017
    • 275
    • Central Utah, USA
    Yes, you could use the Tarot ZYX-S2 as a tail gyro. You will need to keep your Rx's as the ZYX-S2 does not have a built-in Rx. The LEDs on the ZYX-S2 work like the old style tail gyros - RED for heading hold, BLUE for rate mode.
    Note that the ZYX-S2 setup software is Windows only.
    I'm currently using three Tarot ZYX-S2 FBL gyros on three electric 450 helis (two Rotorscale scale jobs and one Tarot 450 Sport FBL) and am having very good luck with them so far. They seem to be pretty vibration tolerant so I would guess that it would work ok in your nitros.
