Bind Futaba T6K to XK K130
  • Bind Futaba T6K to XK K130
    Hello I’m have trouble binding my Futaba T6K to my XK K130. The helicopter is bound to the X6 transmitter it came with but I want to use my Futaba. I plug in the batt and push the button for 1 sec and the red light goes off then I put my Tx in bind mode but nothing happens. The throttle is all the way down and throttle hold is on. The battery is fully charge. Any help would be greatly appreciated.
    They are supposed to be compatible...have you set the tx to heli mode?
      Yes. It bound to my K100 with no issues.
        Wow....OK.
        Umm....sometimes a tx binds better if you stand further away from the rx. Some even want you to stand with your back to the rx, becuase sometimes the signal is actually too strong to bind.
        Maybe try that...
        Good luck!
          I'm not familiar with your specific radio, but the author of this video also had trouble binding to the k130 initially and had to adjust the binding frequency to achieve it.
          Take a look: https://www.youtube.com/watch?v=VVhg...youtu.be&t=668
