Rotor scale 450 AH-6 tail rotor
  • Smitty105
    • Jun 2020
    I got problems. It seems like as I run the heil. I increase the speed i.e rotor speed, the tail rotor sometime just stop spinning. What am I doing wrong?
  • Seaharrierman
    Scale Helicopter Builder/Pilot & Fixed Wing Pilot
    • Jul 2019
    • 45
    what mechanics are you using and the drive system to the tail?
    • Smitty105
      • Jun 2020
      I have the RotorScale 450 helicopter. Tail rotor is belt driven. The main motor is 450L 1800kv Brushless motor. I have no other info on the tail rotor. Thank you for answering.
      • Seaharrierman
        • Jul 2019
        • 45
        are you running 3s or 6s battery with that motor?
        First thing you need to do is check the belt is tensions. If its too loose it can loose engagement
