Official RotorScale C129 Firefox 120 Size Helicopter Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    C129 Firefox 120 Size Gyro Stabilized Helicopter - RTF from RotorScale - RSH1000-001
    An easy to fly, gyro-stabilized helicopter in an All-In-One RTF ("Ready To Fly") package is great for beginner pilots. Its simplified layout is easy to repair and Motion RC carries a full range of spare parts at an affordable price.
    This small, yet feature rich, micro helicopter is fun and easy to fly. The Firefox comes with both blue and orange fuselages, allowing to fly the color you want. The included 2.4GHz transmitter can be used in Mode 1 or Mode 2, giving you complete control over how you want to fly. The 6-axis gyro and flybarless system grants stability not often found in helicopters of this size.
    The C129 Firefox is extremely beginner friendly. One Touch Takeoff - with just a single press of a button the helicopter will take off to an altitude of 1.5 meters. While the throttle stick is neutral the helicopter will hold any height, via a barometric sensor. Pressing and holding the altitude button for 3 seconds will initiate the emergency stop function and instantly halt the motor.
    Being flybarless increases flight time and, in the event of a crash, reduces the risk of damage. The included modular battery is quick and easy to install, giving a duration of up to 15 minutes, and charges quickly with the supplied USB charger.
    RTF - "Ready To Fly"
    Perfect for new pilots, the RotorScale C129 includes everything in the box to begin flying in minutes, except for four AA batteries. Basic spares are included in the box, such as main and tail blade sets, and Motion RC also stocks a complete line of spare parts to keep you flying.
    Gyro-Stabilized
    The integrated gyro system stabilizes the C129 helicopter in six axes. This system arrives fully configured from the factory and requires zero setup by the pilot, and enables special features like "One Touch Takeoff".
    Everyday Flyer
    At 268mm (10.5") in fuselage length with a 249mm (9.8") main rotor diameter, the Firefox is a 250 Class size helicopter that is perfectly sized for everyday flying. Economical and with low-mass, the C129 is a great starting point for new helicopter pilots. Large enough to be flow outdoors in mild wind, the bright fuselages make it easy to see and orient.
    Precision Servo and Motor
    The 2g digital servo offers precise control and high torque. This, in turn, helps prevent accidental damage and extends the life of the helicopter. The 8520 coreless motor resists demagnetization and temperatures up to 150°C.
    Durable Materials
    Specific blends of materials are used to create different parts for different purposes. For example, the landing gear is made of a nylon blend to resist rough landings. The fuselage is made of a blister material to protect against impact, and the tail boom is made of a rigid carbon tube to stabilize the tail motor throughout all maneuvers.
    Reliable Radio Control
    Featuring a modern 2.4GHz radio transmitter, the Firefox can be operated near other RC aircraft and vehicles without risk of losing signal. Fly with confidence with this easy to use radio.
    • RTF ("Ready To Fly") format requires only four AA batteries to begin flying
    • Altitude hold with a barometric sensor
    • Pre-installed integrated 6-axis gyro and flybarless system
    • One Touch Takeoff
    • Durable parts with easy-to-repair design
    • RotorScale C129 Firefox 120 Size Gyro Stabilized Helicopter - RTF
    • Both Blue and Orange Fuselages
    • 2.4GHz Radio Transmitter
    • Flight Battery
    • USB Charger
    • Spare Main Blade Set
    • Spare Tail Blade Set
    • Spare Linkage Rod Set
    • Tools
    • Manual
    Requires:
    • 4x AA batteries
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Class / Size 250 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Plastic
    Overall Size (L x W x H) 267mm (10.5") x 248mm (9.8") x 80mm (3.1")
    Flying Weight 50g
    Main Rotor Diameter 248mm / 9.8"
    Main Rotor Blade Length 248mm / 9.8"
    Tail Rotor Diameter N/A
    Tail Rotor Blade Length N/A
    Tail Drive Type 0615 Brushed Motor
    Cyclic Servos N/A
    Tail Servo N/A
    Power System 8520 Brushed Motor
    Electronic Speed Control Integrated
    Recommended Battery 1S 3.7V 300mAh 25C LiPo Case Battery (Included)
    Required Radio 2.4GHz Radio (Included)
    Skill Level Beginner
    Build Time None
    Recommended Environment Large Indoor or Outdoor Area
