Official RotorScale F01 180 Size Helicopter Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    F1 180 Size Gyro Stabilized Helicopter - RTF from RotorScale - RSH1003-001
    The RotorScale F01 helicopter is perfect for intermediate and advanced pilots looking for a gyro-stabilized helicopter in an All-In-One RTF ("Ready To Fly") package that includes everything you need to fly within minutes. Just add four AA batteries!
    Constructed from a blend of semi-rigid composite materials, CNC aluminum, and carbon fiber, the RotorScale F01 features dual brushless motors and is built for agility.
    An on-board gyro system stabilizes the helicopter in "6G" mode, allowing for hands-off hover to help you learn how to properly orient and control an RC helicopter. Independent brushless motors for the main rotor and tail rotor respond quickly to control inputs, and its advanced "3D" mode unlocks the full potential of this precise flying machine.
    The RotorScale F01 180 size gyro stabilized helicopter delivers balanced performance and value for intermediate heli pilots sharpening their skills toward larger 3D aircraft.
    High Value for High Performance
    The RotorScale F1 is a well balanced machine for the aspiring RC helicopter pilot. Its gyro-stabilized "6G" mode is excellent for newer pilots, and its thrilling "3D" mode unlocks an entirely more advanced type of aerial acrobatic flight performance.
    RTF - Ready To Fly
    Everything is included in the box except for four AA batteries. Simply charge the included flight battery with the included USB charger, insert your four AA batteries into the included radio transmitter, then read the manual in preparation for your first flight. Additional spare parts and tools are included in the box, and Motion RC's complete line of spare parts online is available to keep you flying!
    Dual Brushless Motors
    Most helicopters in this size range use a brushed tail motor, but the RotorScale F1 features a brushless tail motor in a CNC aluminum mount. The brushless motor is more efficient and responsive, giving you better control of the aircraft at all times.
    Futaba S-FHSS Compatible Radio System
    A modern 2.4GHz radio transmitter is included and arrives fully configured to fly your RotorScale F1 helicopter. Zero user programming is required. The helicopter itself is also compatible with Futaba S-FHSS compatible radio transmitters.
    CNC Metal Parts
    In addition to carbon fiber and durable nylon structures, the RotorScale F1 further distinguishes itself from other helicopters in its class with the F1's CNC metal parts. The entire main rotor head assembly is made of metal to provide the highest strength and rigidity to withstand the rigors of 3D flight.
    Fully Featured
    The RotorScale F1 shines as a "dual role" helicopter. Its onboard gyro system self-stabilizes the helicopter for mild flying, its size is perfect for daily use, and its efficient power system is few with economically priced batteries. Stock up on spare batteries and spare parts with Motion RC's full line of RotorScale supporting acccessories.
    • Pre-configured 6-axis gyro stabilized flybarless system
    • Full metal main rotor assembly
    • Brushless main motor
    • Brushless tail motor
    • Pre-configured radio for three modes: Gyro-Stabilized, Sport, and 3D/Aerobatic
    • Compatible with Futaba S-FHSS
    • RotorScale F1 180 Size Gyro Stabilized Helicopter - RTF
    • 2.4GHz Radio Transmitter
    • Flight Battery (2S 7.4V 700mAh 20C LiPo with JST Connector)
    • USB Charger
    • Spare Main Blade Set
    • Spare Tail Blade Set
    • Tools
    • Manual
    Requires:
    • 4x AA batteries
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : None
    Class / Size 180 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Plastic
    Overall Size (L x W x H) 345mm (13.6") x 350mm (13.8") x 108mm (4.3")
    Flying Weight 156g
    Main Rotor Diameter 350mm / 13.8"
    Main Rotor Blade Length 350mm / 13.8"
    Tail Rotor Diameter 62.5mm / 2.5"
    Tail Rotor Blade Length 62mm / 2.5"
    Tail Drive Type 1103 Brushless Motor
    Cyclic Servos N/A
    Tail Servo N/A
    Power System 1312 Brushless Motor
    Electronic Speed Control Integrated
    Recommended Battery 2S 7.4V 700mAh 25C LiPo Battery with XT30 Connector (Included)
    Required Radio 2.4GHz Radio (Included)
    Skill Level Intermediate
    Build Time None
  • jobinseattle
    • 281
    Does Motion RC just sell the helicopter? I managed to destroy the one I just got.
    My YouTube Channel
    • colaking
      • Mar 2023
      They do sell parts. I had to buy a few. However to fix some things you may have to brush up on your soldering skills. I broke a rear rotor motor mount and it looks like the only way to remove the mount is to cut and resolder wires.
      If you broke the plastic swash plate links (the ones with a ring on each end) the ones from the rotorscale 160 size work. The ones from the 180 are listed as out of stock but they are the same piece with different part numbers.
