EC-135 Fenestron Setup
  • EC-135 Fenestron Setup
    Hello all,
    Recently got a Roban 800 EC-135 with fenestron. I have never setup a fenestron before, and would like to any tips tricks to be on the watch for. I did pick up a super/mega/ultra Torq servo for the tail- 41kg @8.4v. The instructions (which are dated 2016) show them mounting the tail servo way down the boom close to the fenestron itself. However it came with the standard length pushrod, with the pushrod being a heavy duty carbon fiber, which leads be to believe the normal servo placement. I plan on using a Beastx gyro as well... so any gyro settings, mounting tips etc would be appreciated.
    ​​​​ I don't have any tips for you but I would love to build one myself, we just need someone who has built one give us more info on setup, I will be watching your build for sure, which mega torque servo did you go with??.
      Hey DC... I went with the MKS Servos X8 HBL380:
      Specifications:
      Torque:
      @6.0V: 430 oz-in (31 kg-cm)
      @7.4V: 541.6 (39 kg-cm)
      @8.2V: 569.38 (41 kg-cm)
      Speed:
      @6.0V: 0.11 s
      @7.4V: 0.09 s
      @8.2V: 0.08 s
      Weight: 73 g
      Dimension: 40x20x38.5mm
      Working Voltage: 3.5 ~ 8.4 V (2S LiPo unregulated)
      Working frequency: 1520μs / 333Hz
      Dead Band: 0.0008 ms (Default)
      Bearing: 8x12mm double bearings
      Motor: Japan High Quality Brushless Motor
      Gear: Chrome-Titanium alloy gear
      Electric current draw: 6.2A max. (8.2V) / 5.8A max. (7.4V) / 4.7A max. (6.0V)
        Got it thanks, keep us posted on your build and problems you may encounter, I have been holding off building one with the fenestron tail because there really isn't to many build videos out there I don't think, so any info and up close pic of your build would be great. Thanks
          Not me. Every time I watch one of his videos it costs me $200.
            Watching, Would love a Blue thunder with Fenestron tail as is scale.
            Gravy
              You got that right...
                I got three more on my list I want to build, but no more $$$$ left.....
                  Spend it. More will come.
                    Don't let Ppaw encourage you!! He's an enabler!!
                      Make sure you use the correct KV motor with the fenestrons. You will need a EgoDrift 460kv as Scale Flying suggests. We have 2 flying down here and once the motors were swapped for the correct KV all of the issues went away. We found out that we were spinning the tails too fast. I think you are good on the servo selection. You need tons of torque with hem. Hopes this helps.
                        What headspeed are you flying at?
                        • #13
                          About 1450
                          • #14
                            About 1450
                            1450... with a 470kv motor? So are ya'll running 14S?
                            • #15
                              12S.
                              This is second hand info from the guys that have them.
                              • #16
                                12S.
                                I gotcha! Thanks for the info!
