I will try to make this as brief as I can. Unfortunately I crashed my Roban 700 Apache mechanics while on it test platform. The talk to was damaged and I have been unable to purchase a replacement due to the shortages with Roban. However I was able to obtain a tour tube meant for the cobra. And although it is identical in diameter it is about an inch longer than the torque tube for the Apache. So I am left with two options. I was thinking of cutting the length Of section out of the tube and then using a smaller piece of tube insert and re-glue everything together.
But I was actually hoping to be able to just cut off the tube to the proper links, and re-tap the thread and screw in the end piece. This would be the ideal, and preferred, method. But these are left hand threads and I have no idea how to identify the size. Is there anyone out there who might know the size tap needed to create the threads?
