Official Roban 800 Size Airwolf Scale Helicopter ARF Thread
    • 8231
    Airwolf 800 Size Scale Helicopter ARF (Almost Ready to Fly) from Roban - RBN-AWS8
    This is the Roban Airwolf Scale 800 ARF, a premium scale kit that offers unparalleled detail. From tip-to-tail the Airwolf body kit displays an accuracy of detail to the fictional full scale aircraft from the TV series, the kind of attention to detail not normally seen in the RC helicopter hobby.
    This kit comes with a fully illuminated scale detail cockpit with illuminated instrument panel and overhead panel, joysticks, rudder pedals, aerials, windshield wipers, antenna, weapons, the special camera on each side of the fuselage and more. Floor and ceiling details can be crafted so once the interiors are installed you have an impressively scaled cockpit/interior. This kit includes electric retracts that are easy to install for that extra level scale appeal.
    These scale kits house the cockpit in precisely the right location and the mechanics are built into the engine compartment just like in the full scale version. The Airwolf really impresses with the highly detailed and accurately scaled down profile.
    Features:
    • 2 Blade rotorhead and scale carbon fiber rotor blades
    • 2 Tail blade head and scale carbon fiber tail blades
    • Extremely detailed surface with molded panel lines and rivets
    • 3-Point electric retract system for the ultimate scale finishing touch
    • Completely illuminated scale cockpit
    • Complete built In / partially pre-installed position lighting system (Controlled via AUX channel)
    • Special CCPM mechanics built in the top section like the full scale
    • Take off weight of 9kg (19.8 pounds)
    • 1794mm long (71")
    Includes:
    • Roban Airwolf 800 size scale body
    • Full 800 size helicopter mechanics
    • 2 Carbon fiber rotor blades
    • 2 Carbon fiber tail blades
    • Complete illuminated scale cockpit
    • Complete built in / partially pre-installed position lighting system
    • 3-Point electric retract system (not installed)
    Requires:Important Information - Please Read
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Expert
    BUILD TIME: 4+ hours
    Class / Size 800
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1850 x 580 x 510mm
    Flying Weight 8,500g
    Main Rotor Diameter 1660mm
    Main Rotor Blade Length 750mm
    Tail Rotor Diameter 280mm
    Tail Rotor Blade Length 105mm
    Tail Drive Type Torque Tube
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 560Kv Brushless Motor
    Electronic Speed Control 160A High Voltage with EC5 Connector
    Recommended Battery 2x 6S 22.2V 5000 mAh LiPo with EC5 Connector (in series for 12S)
    Required Radio 8 Channel
    Skill Level Expert
    Build Time 4+ Hours
  • Seba
    • Jun 2022
    Hi,was looking for someone with the same iterrests, and some tips,
    just got the Roban Airwolf 800....still completing electronics...
    What motor did you put in ? (voltage)I got the 560v .....and extensions 4" or 8" ?
    • Roguemonkey
      • Nov 2019
      • 16
ID:	422005 Click image for larger version
ID:	422004 Click image for larger version
ID:	422003 I bought an Airwolf from scale.De back in 2018. It was the full matte black version. I’ve recently taken it out again to upgrade the hardware in it. Originally I installed a Scorpion, 4035 550 kv, Ikon flybarless and MKS HBL 550 servos X4. I changed the motor to an Egodrift 4525 530 kv, changed all the ball links and replaced the blades with align 800’s. It’s a nicer flying ship. I also changed the nose scale details. I made an actual fue
      • carlos64030
        • Sep 2018
        • 5
        The recommended MKS HBL980 tail servo has a pretty low torque rating:
        Torque @ 6.0V - 4.5 kg/cm (62.5 oz/in)
        Torque @ 7.4V - 5.6 kg/cm (77.77 oz/in)
        Is this servo really sufficient for this 2 blade tail rotor, fairly large size heli? For anyone using this servo, please comment whether it does or does not do a good job with tail holding power.
