Official Roban 800 Size EC-130 Med Flight Scale Helicopter ARF Thread
    • 8231
    EC-130 Med Flight 800 Size Scale Helicopter ARF (Almost Ready to Fly) from Roban - RBN-130MF-8
    This is the Roban EC-130 Med Flight 800 size ARF, a premium scale kit that offers unparalleled detail. From tip-to-tail the EC-130 body kit displays an accuracy of detail to the real aircraft not normally seen in the RC helicopter hobby.
    With the EC-130, Roban brings another super scale model in the fenestron area onto the market. The EC-130, with a very distinctive design and the very unusual three seats in the front. Worldwide, this model is mainly used in sightseeing flights and in the rescue sector.
    Like all super scale models, this EC-130 has a detailed hull with rivets, sheet metal joints and many details. All doors are functional, the cockpit is illuminated and the passenger area has been completely expanded.
    The mechanism used here is the HSM-800 mechanism, in the 2019 version. The mechanism is already in use in several thousand models and has more than proven itself over the past five years. The same goes for the Fenestron unit, which is now used in more than 2000 models. A proven and robust drive concept. Mechanics are of course built in so that you can't see anything of them.
    The hood of the model can be removed to access the batteries. These are stored directly under the mechanics and thus favor the center of gravity of the model.
    These scale kits house the cockpit in precisely the right location and the mechanics are built into the engine compartment just like in the full scale version. The EC-130 really impresses with the highly detailed and accurately scaled down profile.
    • 3 Blade rotorhead and scale carbon fiber rotor blades
    • Upgraded to latest 8 blade 160mm Fenestron and scale carbon fiber tail blades that allows for 30% negative thrust and a low force tail servo at full rpm
    • Extremely detailed surface with molded panel lines and rivets
    • Complete 7 seat scale cockpit
    • Complete built In / partially pre-installed position lighting system (Controlled via AUX channel)
    • Special CCPM mechanics built in the top section like the full scale
    • Take off weight of 8kg (approximately double of a 700 3D helicopter)
    • 1765mm long, 1/8 scale
    • Roban EC-130 Med Flight 800 size scale body
    • Full 800 size helicopter mechanics
    • 3 Carbon fiber rotor blades
    • 8 blade 160mm Fenestron
    • Complete built in / partially pre-installed position lighting system
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Expert
    BUILD TIME: 4+ hours
    Class / Size 800
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1960 x 355 x 510mm
    Flying Weight 8000g
    Main Rotor Diameter 1660mm
    Main Rotor Blade Length 750mm
    Tail Rotor Diameter 160mm
    Tail Rotor Blade Length 70mm
    Tail Drive Type Torque Tube
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 500Kv Brushless Motor
    Electronic Speed Control 160A High Voltage with EC5 Connector
    Recommended Battery 2x 6S 22.2V 5000 mAh LiPo with EC5 Connector (in series for 12S)
    Required Radio 8 Channel
    Skill Level Expert
    Build Time 4+ Hours
