Official Roban 800 Size UH-1N Marines Scale Helicopter ARF Thread
    • 8231
    UH-1N Marines 800 Size Scale Helicopter ARF (Almost Ready to Fly) from Roban - RBN-212GR-8
    The UH-1N Iroquois is a light-lift utility helicopter and was developed as a twin engine follow on to the ubiquitous UH-1H Huey. The aircraft is primarily used by the US Marines and Air Force, as well as numerous other countries, for a wide variety of missions. These primarily include: troop transport, airlift of emergency security forces, and security and surveillance of off-base nuclear weapons convoy. The civilian version, the B212, is also used for a wide variety of missions including: disaster response operations, search and rescue, medical evacuation, airborne cable inspections, support to aircrew survival school, aerial testing, routine missile site support and transport.
    This is the Roban UH-1N Marines Scale 800 ARF. A premium scale kit that offers unparalleled detail. From tip-to-tail the UH-1N Marines body kit displays an accuracy of detail to the real aircraft not normally seen in the RC helicopter hobby. This kit comes with a very high level of detail. The fuselage is pre-painted, windows installed and all structural bulkheads installed. All doors are pre-fitted and fully operational, navigation and strobe lights included.
    This kit comes with a fully illuminated scale detail cockpit with illuminated dashboard, joysticks, rudder pedals, aerials, windshield wipers and more. Full rear cabin interiors are included (not installed). Floor and ceiling details can be crafted so once the interiors are installed you have an impressively scaled cockpit/interior. Balance bar upgrade is available for the rotor head (sold separately).
    The working/sliding door easily opens and allows quick access to the removable floor panel and battery compartment. These scale kits house the cockpit in precisely the right location and the mechanics are built into the engine compartment just like in the full scale version. The UH-1N Marines kit really impresses with the highly detailed and accurately scaled down profile.
    • 2 Blade rotorhead and scale carbon fiber rotor blades
    • 2 Tail blade head and scale carbon fiber tail blades
    • Extremely detailed surface with molded panel lines and rivets
    • Complete 7 seat scale cockpit
    • Complete built In / partially pre-installed position lighting system (Controlled via AUX channel)
    • Special CCPM mechanics built in the top section like the full scale
    • Take off weight of 8kg (approximately double of a 700 3D helicopter)
    • Roban UH-1N Marines 800 Size Scale Body
    • Full 800 size helicopter mechanics
    • 2 Carbon fiber rotor blades
    • 2 Carbon fiber tail blades
    • Complete built in / partially pre-installed position lighting system
    • Instruction manual
    • Decal set
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Expert
    BUILD TIME: 4+ hours
    Class / Size 800
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1960 x 355 x 510mm
    Flying Weight 8,000g
    Main Rotor Diameter 1660mm
    Main Rotor Blade Length 750mm
    Tail Rotor Diameter 280mm
    Tail Rotor Blade Length 105mm
    Tail Drive Type Torque Tube
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 560Kv Brushless Motor
    Electronic Speed Control 160A High Voltage with EC5 Connector
    Recommended Battery 2x 6S 22.2V 5000 mAh LiPo with EC5 Connector (in series for 12S)
    Required Radio 8 Channel
    Skill Level Expert
    Build Time 4+ Hours
