Official Roban 800 Size B222 Mercy Air Medic Scale Helicopter ARF Thread
    • 8231
    B222 Mercy Air Medic 800 Size Scale Helicopter ARF (Almost Ready to Fly) from Roban - RBN-B222-MF
    The B222 was the first light commercial twin turbine engine helicopter developed in the United States. Developed as a larger follow on to the popular Model 206, the Model 222 incorporated a variety of state of the art technologies for its time. This included vibration reduction systems, provisions for IFR avionics, and dual hydraulic and electrical systems. The aircraft also had the option to be configured either with skids or retractable landing gear depending on the needs of the user. The 222 is primarily used for corporate transport and emergency medical or utility transport missions, with seating for up to 10 including the pilot. In popular culture, a modified 222 also starred in the Airwolf TV series as a fictional sleek and powerful attack helicopter.
    This is the Roban B222 Mercy Air Medic Scale 800 ARF. A premium scale kit that offers unparalleled detail. From tip-to-tail the B222 body kit displays an accuracy of detail to the real aircraft not normally seen in the RC helicopter hobby.
    This kit comes with a fully illuminated scale detail cockpit with illuminated dashboard, joysticks, rudder pedals, aerials, windshield wipers and more. Full rear cabin interiors are included (not installed). Floor and ceiling details can be crafted so once the interiors are installed you have an impressively scaled cockpit/interior.
    These scale kits house the cockpit in precisely the right location and the mechanics are built into the engine compartment just like in the full scale version. The B222 really impresses with the highly detailed and accurately scaled down profile.
    • 2 Blade rotorhead and scale carbon fiber rotor blades
    • 2 Tail blade head and scale carbon fiber tail blades
    • Extremely detailed surface with molded panel lines and rivets
    • Completely illuminated scale cockpit
    • Complete built In / partially pre-installed position lighting system (Controlled via AUX channel)
    • Special CCPM mechanics built in the top section like the full scale
    • Take off weight of 8.5kg (approximately double of a 700 3D helicopter)
    • 1794mm long, 1/8 scale
    • Roban B222 Mercy Air Medic 800 size scale body
    • Full 800 size helicopter mechanics
    • 2 Carbon fiber rotor blades
    • 2 Carbon fiber tail blades
    • Complete illuminated scale cockpit
    • Complete built in / partially pre-installed position lighting system
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Expert
    BUILD TIME: 4+ hours
    Class / Size 800
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1850 x 580 x 510mm
    Flying Weight 8500g
    Main Rotor Diameter 1660mm
    Main Rotor Blade Length 750mm
    Tail Rotor Diameter 280mm
    Tail Rotor Blade Length 105mm
    Tail Drive Type Torque Tube
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 500Kv Brushless Motor
    Electronic Speed Control 160A High Voltage with EC5 Connector
    Recommended Battery 2x 6S 22.2V 5000 mAh LiPo with EC5 Connector (in series for 12S)
    Required Radio 8 Channel
    Skill Level Expert
    Build Time 4+ Hours
  • Paul Mroz
    • 3
    HI, Love this Heli,
    I've just started this build, and have a few questions, where do you put 2 battery in this thing. LOL no room as you have all the seta and no access under the sets.
    Cheers Paul
      • 2818
      • Arlington, TX
      Originally posted by Paul Mroz
      HI, Love this Heli,
      Cheers Paul
      There is a battery tray right over the cockpit, in the forward section of the cowling. It fits 2 6S 5000s side by side.
