Moved to:
Official Roban 700 Size B429 Heli Alps Scale Helicopter ARF Thread
Official Roban 700 Size B429 Mercy Flight Scale Helicopter ARF Thread
Thanks for the link, I downloaded his build notes before I got the heli. It took 11 weeks two days to get here, so I used the time to research it. I bought it directly from Roban, fantastic to deal with and they informed me every step it took from the factory to the ship and then to me. I would buy from them again. I got a parts list from them and I can get the spares for it should I need them.Leave a comment:
I'm about half way through building mine, the mechanics are not fitted, I just wanted a reference point for it. It makes my 550 jet ranger look small, 😂 I'm not sure it's going to fit in the car? I might be in the market for a van....😅
Happy new year all.....1 PhotoLeave a comment:
Check out this link: https://erdlenbruch.de/Burkhard/Mode...tB429.html#How
I will also start a build log when mine arrives. The accessories (motor, FBL, servos, etc) arrived today.Leave a comment:
Yup, me too, today. My winter project. Has anyone built one, you tube vid etc?Leave a comment:
I bought one and it truly is one good looking bird! I haven't had a chance to actually fly it yet due to some FBL programming issues, but I'm certainly looking forward to getting this beauty in the air.Leave a comment:
This is the Roban B429 Mercy Flight 700 size ARF, a premium scale kit that offers unparalleled detail. From tip-to-tail the B429 body kit displays an accuracy of detail to the real aircraft not normally seen in the RC helicopter hobby.
This kit comes with a full scale detail cockpit with dashboard, joysticks, rudder pedals, aerials, windshield wipers and more. Full rear cabin interiors are included (not installed). Floor and ceiling details can be crafted so once the interiors are installed you have an impressively scaled cockpit/interior.
These scale kits house the cockpit in precisely the right location and the mechanics are built into the engine compartment just like in the full scale version. The B429 really impresses with the highly detailed and accurately scaled down profile.
Features:- 4 Blade rotorhead and scale carbon fiber rotor blades
- 4 Tail blade head and scale carbon fiber tail blades
- Extremely detailed surface with molded panel lines and rivets
- Complete 7 seat scale cockpit
- Complete built In / partially pre-installed position lighting system (Controlled via AUX channel)
- Special CCPM mechanics built in the top section like the full scale
- Take off weight of 8kg (approximately double of a 700 3D helicopter)
- 1700mm long, 1/8 scale
- Roban B429 Mercy Flight 700 size scale body
- Full 700 size helicopter mechanics
- 4 Carbon fiber rotor blades
- 4 Carbon fiber tail blades
- Helicopter flight controller - we recommend the BavarianDEMON 3X Flybarless System
- Electronic speed control (ESC) - we recommend the Castle Creations Phoenix Edge High Voltage 160A ESC With Cooling Fan
- Battery eliminator circuit (BEC) - we recommend the Castle Creations 20A BEC Pro
- Brushless motor - we recommend the Scorpion HKIII 4035-500Kv brushless motor
- Three cyclic servos - we recommend the MKS DS1220 High Torque Servo Multi-Pack (3 Servos)
- Tail servo - we recommend the MKS DS HBL669
- 12 Cell 44.4V 5000mAh LiPo battery - we recommend the Admiral 5000mAh 6S 22.2V 50C LiPo Battery Multi-Pack in series
- 8 Channel radio - select a minimum 8 channel radio with pitch and throttle curves from our Radio Collection
- 8 Channel receiver - select a minimum 8 channel receiver from our Receiver Collection
Product Specifications:
AGE LEVEL: 18 and up
SKILL LEVEL: Expert
BUILD TIME: 4+ hours
Class / Size 700 Power Type Electric Rotor Type Collective Pitch Body Material Fiberglass Overall Size (L x W x H) 1870 x 510 x 330mm Flying Weight 8000g Main Rotor Diameter 1560mm Main Rotor Blade Length 700mm Tail Rotor Diameter 280mm Tail Rotor Blade Length 105mm Tail Drive Type Torque Tube Cyclic Servos 3x Metal Gear Tail Servo 1x Metal Gear Power System 450Kv Brushless Motor Electronic Speed Control 120A High Voltage with EC5 Connector Recommended Battery 2x 6S 22.2V 5000 mAh LiPo with EC5 Connector (in series for 12S) Battery Compartment Size (L x W x H) N/A Required Radio 7 Channel Skill Level Expert Build Time 4+ Hours Recommended Environment Outdoors
