This is the Roban B206 News 700 scale conversion kit. A premium scale kit that offers unparalleled detail. From tip-to-tail the B206 body kit displays an accuracy of detail to the real aircraft not normally seen in the RC helicopter hobby.
These scale kits house the cockpit (sold separately) in precisely the right location and are designed to fit your trex 700 mechanics or similar. The B206 really impresses with the highly detailed and accurately scaled down profile.
Originally developed as the YOH-4 for the United States Army's Light Observation Helicopter program, the Model 206 Jetranger was one of the first a generation of light single engine helicopters. Despite a losing the competition, the airframe was redesigned and successfully marketed to both commercial markets as the Jetranger, and military markets as the OH-58 Kiowa.
Commercially, the aircraft is one of the successful and recognizable helicopters ever produced. It has starred in films, served police and fire departments, fought in multiple wars, transported VIPs, flown aerial tours, trained generations of soldiers and Marines to fly, and operated as a medical transport.
- Extremely detailed surface with molded panel lines and rivets
- Use of 750MX standard equipment (12S Battery, 530Kv motor), fly with your existing parts
- Take off weight of 8kg (approximately double of a 700 3D helicopter)
- 1750mm long, 1/8 scale
- Roban B206 Stars and Stripes 700 body kit
- 700 Size helicopter kit - we recommend the Phoenixtech Flasher 700 helicopter Kit
- Helicopter flight controller - we recommend the BavarianDEMON 3X Flybarless System
- Electronic speed control (ESC) - we recommend the Castle Creations Phoenix Edge 130A ESC with 5A BEC
- Battery eliminator circuit (BEC) - we recommend the Castle Creations 20A BEC Pro
- Brushless motor - we recommend the Scorpion HKIV 4025-1100Kv Brushless Motor
- Three cyclic servos - we recommend the MKS DS1220 High Torque Servo Multi-Pack (3 Servos)
- Tail servo - we recommend the MKS HBL669 Tail Servo
- 6 Cell 22.2V 5000mAh LiPo battery - we recommend the Admiral 5000mAh 6S 22.2V 50C LiPo Battery
- 8 Channel radio - select a minimum 8 channel radio with pitch and throttle curves from our Radio Collection
Product Specifications:
AGE LEVEL: 18 and up
SKILL LEVEL: Expert
BUILD TIME: 4+ hours
| Class / Size | 700 |
| Power Type | Electric |
| Rotor Type | Collective Pitch |
| Body Material | Fiberglass |
| Overall Size (L x W x H) | 1870 x 510 x 330mm |
| Flying Weight | 8000g |
| Main Rotor Diameter | 1560mm |
| Main Rotor Blade Length | 700mm |
| Tail Rotor Diameter | 280mm |
| Tail Rotor Blade Length | 105mm |
| Tail Drive Type | Torque Tube |
| Cyclic Servos | 3x Metal Gear |
| Tail Servo | 1x Metal Gear |
| Power System | 1100Kv Brushless Motor |
| Electronic Speed Control | 120A High Voltage with EC5 Connector |
| Recommended Battery | 6S 22.2V 5000 mAh LiPo with EC5 Connector |
| Battery Compartment Size (L x W x H) | N/A |
| Required Radio | 7 Channel |
| Skill Level | Expert |
| Build Time | 4+ Hours |
