Official Roban 700 Size MD-500E G-Jive Blue Scale Helicopter Conversion Kit Thread
    • 8231
    MD-500E G-Jive Blue 700 Size Helicopter Scale Conversion Kit from Roban - RBN-KF500GJB7
    This is the Roban MD-500E G-Jive Blue 700 scale conversion kit, a premium scale kit that offers unparalleled detail. From tip-to-tail the MD-500E body kit displays an accuracy of detail to the real aircraft not normally seen in the RC helicopter hobby.
    These scale kits house the cockpit (sold separately) in precisely the right location and the mechanics are built into the engine compartment just like in the full scale version. The MD-500E really impresses with the highly detailed and accurately scaled down profile.
    • Extremely detailed surface with molded panel lines and rivets
    • Use of 750MX standard equipment (612S Battery, 450Kv motor), fly with your existing parts
    • Take off weight of 8kg (approximately double of a 700 3D helicopter)
    • Roban MD-500E G-Jive Blue 700 body kit
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Expert
    BUILD TIME: 4+ hours
    Class / Size 700
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1670 x 480 x 610mm
    Flying Weight 8000g
    Main Rotor Diameter 1360mm
    Main Rotor Blade Length 700mm
    Tail Rotor Diameter 280mm
    Tail Rotor Blade Length 105mm
    Tail Drive Type Torque Tube
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 1100Kv Brushless Motor
    Electronic Speed Control 120A High Voltage with EC5 Connector
    Recommended Battery 6S 22.2V 5000 mAh LiPo with EC5 Connector
    Required Radio 7 Channel
    Skill Level Expert
    Build Time 4+ Hours
