AS350 San Diego Police 700 Size Scale Helicopter ARF (Almost Ready to Fly) from Roban - RBN-AS350SDP-7S
This is the Roban Eurocopter AS350 Scale 700 ARF in San Diego Police color scheme. A premium scale kit that offers unparalleled detail. From tip-to-tail the AS350 body kit displays an accuracy of detail to the real aircraft not normally seen in the RC helicopter hobby.
This kit comes with a full scale detail cockpit with dashboard, joysticks, rudder pedals, aerials, windshield wipers and more. Full rear cabin interiors are included (not installed). Floor and ceiling details can be crafted so once the interiors are installed you have an impressively scaled cockpit/interior.
These scale kits house the cockpit in precisely the right location and the mechanics are built into the engine compartment just like in the full scale version. The AS350 really impresses with the highly detailed and accurately scaled down profile.
Features:
  • 3 Blade rotorhead and scale carbon fiber rotor blades
  • 2 Tail blade head and scale carbon fiber tail blades
  • Extremely detailed surface with molded panel lines and rivets
  • Complete 5 seat scale cockpit
  • Complete built In / partially pre-installed position lighting system (Controlled via AUX channel)
  • Special CCPM mechanics built in the top section like the full scale
  • Take off weight of 8kg (approximately double of a 700 3D helicopter)
  • 1750mm long, 1/8 scale
Includes:
  • Roban AS350 San Diego Police 700 size scale body
  • Full 700 size helicopter mechanics
  • 3 Carbon fiber rotor blades
  • 2 Carbon fiber tail blades
Requires:Important Information - Please Read
Product Specifications:
AGE LEVEL: 18 and up
SKILL LEVEL: Expert
BUILD TIME: 4+ hours
Class / Size 700
Power Type Electric
Rotor Type Collective Pitch
Body Material Fiberglass
Overall Size (L x W x H) 1870 x 510 x 330mm
Flying Weight 8000g
Main Rotor Diameter 1560mm
Main Rotor Blade Length 700mm
Tail Rotor Diameter 280mm
Tail Rotor Blade Length 105mm
Tail Drive Type Torque Tube
Cyclic Servos 3x Metal Gear
Tail Servo 1x Metal Gear
Power System 530Kv Brushless Motor
Electronic Speed Control 120A High Voltage with EC5 Connector
Recommended Battery 2x 6S 22.2V 5000 mAh LiPo with EC5 Connector (in series for 12S)
Required Radio 7 Channel
Skill Level Expert
Build Time 4+ Hours
