Official Roban 600 Size Lakota UH-72 Scale Helicopter Conversion Kit Thread
    • 8218
    Lakota UH-72 600 Size Helicopter Scale Conversion Kit from Roban - RBN-KF145MIL6
    The Eurocopter UH-72 Lakota is a twin-engine helicopter with a single, four-bladed main rotor. The UH-72 is a militarized version of the Eurocopter EC145. This is the 600 size Lakota UH-72 version. Designed to take your Chaos 600 or Trex 600ESP torque tube versions* and transform it into a very scale RC version of the full scale helicopter.
    These 600 scale conversion kits from Roban offer special designed side frames which are designed to offer 2 primary special features. One is to lower the transmission which allows the torque tube to travel thru the lower tail boom of the helicopter which has always been a problem with most military helicopters. Probably the most revolutionary design in scale helicopters, these frames allow the entire mechanical system to be tucked up inside the dog house just like the full scale helicopters. No more mechanics taking up the entire fuselage area leaving no room for cockpits, rear seats, etc.
    Most of the work is done for you. All wood work is installed. Pre-drilled holes for easy install of the landing gear. The fuselage provides plenty of room for owners to fully customize to their heart's desire. The kit includes metal landing gear and a raised torque tube drive system. This fuselage has full open door design including pilot, side and cargo doors using the scale door joint hinges. The fuselage is carefully designed utilizing computer 3D renderings and CNC molds providing extreme detail and precision scale panel lines. Standard 600 set up is an 1100 Kv brushless outrunner motor, 80-100 amp ESC and a 6S 22.2V 5000 mAh or higher LiPo battery.
    This fuselage can be completed in as little as 4-6 hrs and is intended for the intermediate to advanced builder. This fuselage includes all the tail gear you need to convert your TrexESP to the raised tail system.
    • Fully painted fiberglass scale fuselage
    • Metal landing gear and magnetic cabin lock system for quick and easy access
    • Extremely detailed surface and molded panel lines
    • Use of 600 standard equipment (6S Battery, 1100Kv motor), fly with your existing parts
    • Roban Lakota UH-72 600 body kit
    Requires:Optional:Important Information - Please Read
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Advanced
    BUILD TIME: 4+ hours
    Class / Size 600
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1460 x 365 x 385mm
    Flying Weight 1500g
    Main Rotor Diameter N/A
    Main Rotor Blade Length N/A
    Tail Rotor Diameter N/A
    Tail Rotor Blade Length N/A
    Tail Drive Type Torque Tube
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 1100Kv Brushless Motor
    Electronic Speed Control 130A High Voltage with EC5 Connector
    Recommended Battery 6S 22.2V 5000 mAh LiPo with EC5 Connector
    Required Radio 7 Channel
    Skill Level Advanced
    Build Time 4+ Hours
  • Camporealer
    • Jun 2020
    Where can you get a 4 blade setup for this Heli?
