Official Roban 600 Size UH-1N Iroquois Scale Helicopter Conversion Kit Thread
    UH-1N Iroquois 600 Size Helicopter Scale Conversion Kit from Roban - RBN-KFUH1NM6
    The UH-1N Twin Huey is a twin-engine military helicopter. A member of the numerous Huey family, it first flew in 1969. The UH-1N has a fifteen-seat configuration, with one pilot and fourteen passengers. This is the 600 size UH-1N Iroquois version. Designed to take your Chaos 600 or Trex 600ESP torque tube versions* and transform it into a very scale RC version of the full scale helicopter. This kit includes everything you need to install your mechanics, including the special shaft-driven raised drive system specially designed for easy plug n play install in the Chaos or Align mechanics.
    These 600 scale conversion kits from Roban offer special designed side frames which are designed to offer 2 primary special features. One is to lower the transmission which allows the torque tube to travel thru the lower tail boom of the helicopter which has always been a problem with most military helicopters. Probably the most revolutionary design in scale helicopters, these frames allow the entire mechanical system to be tucked up inside the dog house just like the full scale helicopters.
    No more mechanics taking up the entire fuselage area leaving no room for cockpits, rear seats, etc.
    Most of the work is done for you. All wood work is installed. Pre-drilled holes for easy install of the landing gear. The optional scale cockpit is completely hand assembled and painted for you in impressive detail. All you need to do is just slide it in place. Decals no more! The cockpit is hand painted with raised details and instruments.
    Because the UH-1N Twin Huey is a 2 blade helicopter, there is no need to change any configuration within the mechanics. If you have an existing good flying 600 helicopter, you will not need to upgrade or change anything. Standard 600 set up is an 1100 Kv brushless outrunner motor, 80-100 amp ESC and a 6S 22.2V 5000 mAh or higher LiPo battery.
    This fuselage can be completed in as little as 4-6 hrs and is intended for the intermediate to advanced builder.
    • Fully painted fiberglass scale fuselage
    • Magnetic cabin lock system for quick and easy access
    • Extremely detailed surface and molded panel lines
    • Use of 600 standard equipment (6S Battery, 1100Kv motor), fly with your existing parts
    • Roban UH-1N Iroquois 600 body kit
    • Scale landing skids
    Requires:Optional:Important Information - Please Read
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Advanced
    BUILD TIME: 4+ hours
    Class / Size 600
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1480 x 330 x 280mm
    Flying Weight 3000g
    Main Rotor Diameter N/A
    Main Rotor Blade Length N/A
    Tail Rotor Diameter N/A
    Tail Rotor Blade Length N/A
    Tail Drive Type Torque Tube
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 1100Kv Brushless Motor
    Electronic Speed Control 130A High Voltage with EC5 Connector
    Recommended Battery 6S 22.2V 5000 mAh LiPo with EC5 Connector
    Required Radio 7 Channel
    Skill Level Advanced
    Build Time 4+ Hours
  • DLHam3463
    • Mar 2024
    • 28
    Does anyone know what the right size/scale pilot figures would be for this kit?
      • 2818
      • Arlington, TX
      Roughly 1/10 scale (1/9.5) is what I used.
      • DLHam3463
        • Mar 2024
        • 28
        Thank you!
        • DLHam3463
          • Mar 2024
          • 28
          I received the UH-1 600 kit. Inventoried and all there, and no issues.
          One initial question. The site mentions landing skid holes are pre-drilled; but I don’t see in mine? What size screws are used?? (Was going to mount them to make fuselage more steady)
          Thanks.
          • DLHam3463
            • Mar 2024
            • 28
            Got it figured out. I found Roban manuals from their site. They were in German so opened them in Word; translated to English then printed!
              • 2818
              • Arlington, TX
              Here’s my build. Some of the photos may be of some help: https://www.hobbysquawk.com/forum/rc...nd-impressions
              • DLHam3463
                • Mar 2024
                • 28
                Thank you!!! Yes will be very helpful. Translating manuals I found also makes clearer!!!
                • DLHam3463
                  • Mar 2024
                  • 28
                  Ok, I give. What is the correct procedure to safely rein or the sliding rear cabin doors without breaking or damaging them?
                  They start to open and feel like binding. Don’t want to force and break them.
                  They do slide fully open, correct??πŸ€”πŸ€”πŸ€”
                    • 2818
                    • Arlington, TX
                    They actually don't, at least not from the factory. I had to take a dremel with the cutoff wheel and extend the slot that the door tabs ride in to get them mostly open.
                    • DLHam3463
                      • Mar 2024
                      • 28
                      Well I carefully got both side doors off and without breaking anything 😎.
                      Yes, I can see the sliding track slot needs some cleaning up!
                      • DLHam3463
                        • Mar 2024
                        • 28
                        For those that have built this kit, do you recall how much (if it was needed) nose weight? Just wanting to get some estimates
                        thanks
                          • 2818
                          • Arlington, TX
                          thanks
                          I unfortunately don't remember exactly how much I added, but it was a lot. That was with one 6S 5800 and the optional cockpit kit installed.
                          • DLHam3463
                            • Mar 2024
                            • 28
                            Progress continues on my build.
                            Can any of you who have completed this build share any photos or advice on servo linkages and placement of the receiver, ESC etc.
                            also glad to hear of things not to do!!!
                            Thanks!
