Official Roban 600 Size MD-500E G-Jive Blue Scale Helicopter Conversion Kit Thread
    • 8211
    MD-500E G-Jive Blue 600 Size Helicopter Scale Conversion Kit from Roban - RBN-KFMD500GJB6
    The MD 500 series is an American family of light utility civilian and military helicopters. The MD 500 was developed from the Hughes 500, a civilian version of the US Army's OH-6A Cayuse/Loach. The successful Hughes 500/MD 500 series began life in response to a U.S. Army requirement for a Light Observation Helicopter (LOH). This is the 600 size MD-500E G-Jive Blue version.
    Most of the work is done for you. All wood work is installed. Pre-drilled holes for easy install of the landing gear. Standard 600 set up is an 1100 Kv brushless outrunner motor, 80-100 amp ESC and a 6S 22.2V 5000 mAh or higher LiPo battery.
    This fuselage can be completed in as little as 4-6 hrs and is intended for the intermediate to advanced builder. No modifications needed when using stock mechanics and stock rotor head.
    Note: As of July 2018, this is an updated version of the MD500 with a full epoxy front fuselage and separate windows.
    Features:
    • Fully painted fiberglass scale fuselage
    • Magnetic cabin lock system for quick and easy access
    • Extremely detailed surface and molded panel lines
    • Use of 600 standard equipment (6S Battery, 1100Kv motor), fly with your existing parts
    Includes:
    • Roban MD-500E G-Jive Blue 600 body kit
    Requires:Optional:Important Information - Please Read
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Advanced
    BUILD TIME: 4+ hours
    Class / Size 600
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1260 x 350 x 480mm
    Flying Weight 1353g
    Main Rotor Diameter N/A
    Main Rotor Blade Length N/A
    Tail Rotor Diameter N/A
    Tail Rotor Blade Length N/A
    Tail Drive Type Torque Tube
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 1100Kv Brushless Motor
    Electronic Speed Control 130A High Voltage with EC5 Connector
    Recommended Battery 6S 22.2V 5000 mAh LiPo with EC5 Connector
    Required Radio 7 Channel
    Skill Level Advanced
    Build Time 4+ Hours
  • Browneye77
    Heli Flyer
    • May 2024
    • 7
    Is there another recommended donor chassis for this one? The phoenixtech ones don't seem to be available. Maybe a T-Rex one or something?
    Chris Brown
    Yakima WA USA
      • 2817
      • Arlington, TX
      That’s a tough one right now. Most modern 3D mechanics have larger diameter booms that don’t fit well in an MD500 airframe. I would personally look for a used Trex 550E, then retrofit a Trex 600 boom and torque tube. Not ideal, but that’s just what I’d go with.
      • Browneye77
        Heli Flyer
        • May 2024
        • 7
        Thanks for replying. You were a BIG help on the other thread on this topic.
        So, same problem for the 600 class as well as the 450 huh? I guess there's just not enough interest in the scale helis. MotionRC sells them, but two grand for a RTR just isn't part of my vision of the future.
        I think I'll order a Tarot 450 kit and a Jet Tech body.
        Chris Brown
        Yakima WA USA
          • 2817
          • Arlington, TX
          No problem. I think the problem is that in the 3D world, these mechanics are considered outdated and no one outside the scale community buys them. The scale community is already small, but narrow that down to just the 600 size, and I can see where it would be difficult to justify production continuing.
          There is a positive to this. Trex 550s and 600s are still out there. 3D pilots sell them off cheap routinely because they are old. Look at RCgroups or Facebook marketplace, or the Facebook for sale groups for RC. I’ve heavily leveraged this to stock up on Trex 500ESPs and parts.
          Why don’t newer 3D helis fit you might ask? Well, the larger boom diameter issue I mentioned is only one small factor. Modern 3D helis have tried to get the CG up close to the mast. So, motors and servos are mounted higher up. Batteries are integrated in between the frames. Main shafts are short with minimal clearance. Gear ratios are designed for high headspeed. Shaft driven tails have all but disappeared. None of these are particularly good for scale helis. This is exactly why Roban has their own mechanics for their main line helis. Same for Vario.
          The 470s aren’t a bad value if you are ok with the motor driven tails. You can always rip out the GPS controller and add a normal FBL unit if you don’t want to use the stock system. At least they include some mechanics.
          The 500s (which Motion no longer sells) are my favorite for the money. They can use the Trex 500ESP mechs or clones (which are still easy to get parts for), and are big enough to carry their weight better than the 450s. You can still get a number of 500 fuselages from Amazon, or flight-model. They should also fit the very inexpensive Steam AK420 mechs, but I haven’t had a chance to try that yet. Multiblade heads and scale blades are also cheap and available.
          As for Jet Tech, the Funkey fuselages are ok for certain models, but in my opinion the Roban fuselages are more detailed. I also don’t like that they come with tinted windows versus the clear ones Roban uses. Something to consider.. Their Bell 222 and A109 do have better outlines than their Roban counterparts though.
          Sorry for the long rant, hope this helps a bit!
