Official Roban 600 Size B222 Airwolf Scale Helicopter Conversion Kit Thread
  • Official Roban 600 Size B222 Airwolf Scale Helicopter Conversion Kit Thread
    B222 Airwolf 600 Size Helicopter Scale Conversion Kit from Roban - RBN-KFHAW6
    Airwolf is the helicopter from the 1980s American television series of the same name. Its fictional features included stratospheric ceiling, stealth noise signature, a wide range of weapons and even supersonic speed. The Airwolf helicopter was a conventional 222 helicopter modified by attaching some film props. This is the 600 size B222 Airwolf version and includes a set of detailed retractable landing gear.
    Most of the work is done for you. All wood work is installed. Pre-drilled holes for easy install of the landing gear. Standard 600 set up is an 1100 Kv brushless outrunner motor, 80-100 amp ESC and a 6S 22.2V 5000 mAh or higher LiPo battery.
    This fuselage can be completed in as little as 4-6 hrs and is intended for the intermediate to advanced builder.
    Features:
    • Fully painted fiberglass scale fuselage
    • Retractable landing gear
    • Magnetic cabin lock system for quick and easy access
    • Extremely detailed surface and molded panel lines
    • Use of 600 standard equipment (6S Battery, 1100Kv motor), fly with your existing parts
    Includes:
    • Roban B222 Airwolf 600 body kit
    Requires:Optional:Important Information - Please Read
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Advanced
    BUILD TIME: 4+ hours
    Class / Size 600
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1300 x 400 x 248mm
    Flying Weight 1200g
    Main Rotor Diameter N/A
    Main Rotor Blade Length N/A
    Tail Rotor Diameter N/A
    Tail Rotor Blade Length N/A
    Tail Drive Type Torque Tube
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 1100Kv Brushless Motor
    Electronic Speed Control 100A with EC5 Connector
    Recommended Battery 6S 22.2V 5000 mAh LiPo with EC5 Connector
    Required Radio 8 Channel
    Skill Level Advanced
    Build Time 4+ Hours
    Hello, Thinking on this 600 size Airwolf conversion kit. What can anyone says about the quality and build
    of this fuselage. Thanks, Jim
      has anybody figured out how to use your own radio on the heli?
        This is just a fuselage kit.. You can use whatever radio and FBL you want.
