Official Roban 600 Size A-109 Coast Guard Scale Helicopter Conversion Kit Thread
    A-109 Coast Guard 600 Size Helicopter Scale Conversion Kit from Roban - RBN-KF-109CG6
    The A109 is a lightweight, twin-engine, eight-seat multi-purpose helicopter built by the Italian manufacturer Leonardo. The rotorcraft had the distinction of being the first all-Italian helicopter to be mass-produced. Originally entered service in 1976 and has since been used in various roles, including light transport, medevac, search-and-rescue, and military roles. The A109 has been in continuous production for 40 years. This is the 600 size A-109 Coast Guard version.
    Most of the work is done for you. All wood work is installed. Tricycle retractable landing gear are included. Pre-drilled holes for easy install of the landing gear. Standard 600 set up is an 1100 Kv brushless outrunner motor, 80-100 amp ESC and a 6S 22.2V 5000 mAh or higher LiPo battery.
    This fuselage can be completed in as little as 4-6 hours and is intended for the intermediate to advanced builder.
    • Fully painted fiberglass scale fuselage
    • Tricycle retractable landing gear
    • Magnetic cabin lock system for quick and easy access
    • Extremely detailed surface and molded panel lines
    • Use of 600 standard equipment (6S Battery, 1100Kv motor), fly with your existing parts
    • Roban A-109 Coast Guard 600 body kit
    Requires:Optional:Important Information - Please Read
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Advanced
    BUILD TIME: 4+ hours
    Class / Size 600
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1300 x 400 x 248mm
    Flying Weight 1200g
    Main Rotor Diameter N/A
    Main Rotor Blade Length N/A
    Tail Rotor Diameter N/A
    Tail Rotor Blade Length N/A
    Tail Drive Type Torque Tube
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 1100Kv Brushless Motor
    Electronic Speed Control 100A with EC5 Connector
    Recommended Battery 6S 22.2V 5000 mAh LiPo with EC5 Connector
    Required Radio 8 Channel
    Skill Level Advanced
    Build Time 4+ Hours
