Official Roban 600 Size EC-145 Swiss Medic Red/White Scale Helicopter Conversion Kit Thread
    • 8231
    EC-145 Swiss Medic Red/White 600 Size Helicopter Scale Conversion Kit from Roban - RBN-KF145RW-6
    The Eurocopter EC145 is a twin-engine light utility helicopter developed and manufactured by Eurocopter, which was rebranded as Airbus Helicopters in 2014. The EC145 is a twin-engine helicopter and can carry up to nine passengers along with two crew, depending on customer configuration. The helicopter is marketed for passenger transport, corporate transport, emergency medical services (EMS), search and rescue, parapublic and utility roles. This is the 600 size EC-145 Swiss Medic Red/White version. Designed to take your Chaos 600 or Trex 600ESP torque tube versions* and transform it into a very scale RC version of the full scale helicopter. This kit includes everything you need to install your mechanics, including the 45 degree angle raised tail gearbox specially designed for easy plug-n-play install in the Chaos or Align mechanics.
    Most of the work is done for you. All wood work is installed. Pre-drilled holes for easy install of the landing gear. Standard 600 set up is an 1100 Kv brushless outrunner motor, 80-100 amp ESC and a 6S 22.2V 5000 mAh or higher LiPo battery.
    This fuselage can be completed in as little as 4-6 hrs and is intended for the intermediate to advanced builder.
    Features:
    • Fully painted fiberglass scale fuselage
    • Magnetic cabin lock system for quick and easy access
    • Extremely detailed surface and molded panel lines
    • Use of 600 standard equipment (6S Battery, 1100Kv motor), fly with your existing parts
    Includes:
    • Roban EC-145 Swiss Medic Red/White 600 - Body Kit
    Requires:Optional:Important Information - Please Read
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Advanced
    BUILD TIME: 4+ hours
    Class / Size 600
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1460 x 365 x 385mm
    Flying Weight 1500g
    Main Rotor Diameter N/A
    Main Rotor Blade Length N/A
    Tail Rotor Diameter N/A
    Tail Rotor Blade Length N/A
    Tail Drive Type Torque Tube
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 1100Kv Brushless Motor
    Electronic Speed Control 120A High Voltage with EC5 Connector
    Recommended Battery 6S 22.2V 5000 mAh LiPo with EC5 Connector
    Required Radio 7 Channel
    Skill Level Advanced
    Build Time 4+ Hours
