Official Roban 500 Size AH-64 Apache Scale Helicopter Conversion Kit Thread
    AH-64 Apache 500 Size Helicopter Scale Conversion Kit from Roban - RBN-KF-AH64G5
    This is a scale representation in the 500 class of the iconic AH-64 Apache helicopter. Designed to take your Chaos 500 or Trex belt drive versions and transform it into a very scale RC version of the twin-turboshaft attack helicopter. This kit includes everything you need to install your mechanics, including the special belt gearbox specially designed for easy plug n play install in the Chaos or Align mechanics.
    There is no extra parts to purchase to get this beautiful scale fuselage in the air. When you open the box, the fuselage is completely painted in standard automotive base coat and clear coat for a super gloss finish. Included are scale aluminum landing gear. Aluminum wheels and foam tires give this kit a very scale look.
    A removable canopy allows easy access to the mechanics and is factory installed with magnets and locating pins. Designed for easy battery removal. This fuselage can be completed in as little as 4-6 hrs and is intended for the intermediate to advanced builder. No modifications needed when using stock mechanics and stock rotor head.
    When planning to use a 4 blade main rotor head and 4 blade tail, it is recommended to upgrade to a lower Kv motor and possibly a high voltage system using 8S two 4S packs in series) or higher.
    • Fully painted fiberglass scale fuselage
    • Belt drive tail elevated rotor set
    • Scale weapons set (guns and missiles)
    • Scale aluminum landing gear
    • Use of 500 standard equipment (6S Battery, 850-1200Kv motor), fly with your existing parts
    • Roban AH-64 Apache 500 body kit
    Requires:Optional:Important Information - Please Read
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Advanced
    BUILD TIME: 4+ hours
    Class / Size 500
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1020 x 355 x 320mm
    Flying Weight 1510g
    Main Rotor Diameter N/A
    Main Rotor Blade Length N/A
    Tail Rotor Diameter N/A
    Tail Rotor Blade Length N/A
    Tail Drive Type Belt
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 850 - 1200Kv Brushless Motor
    Electronic Speed Control 80A ESC with XT60 Connector
    Recommended Battery 2x 4S 14.8V 2600 - 3300 mAh LiPo with XT60 Connector (in series for 8S)
    Required Radio 7 Channel
    Skill Level Advanced
    Build Time 4+ Hours
  • Micirish
    • Dec 2023
    Do you have a apache 500 ? Or know where to get one
      Out of stock.
