Official Roban 500 Size B222 Airwolf Scale Helicopter Conversion Kit Thread
    B222 Airwolf 500 Size Helicopter Scale Conversion Kit from Roban - RBN-KFHAW5
    This is 500 class conversion kit of the B222 Airwolf helicopter from the popular 80's TV series. Designed to take your Chaos 500 or Trex torque tube versions and transform it into a scale RC version of the twin-turboshaft civilian helicopter. This kit includes the scale body with mechanical retracts (one servo is required but not included to operate all three retracts). CNC Aluminum landing gear is also included as is a side weapon set, tail fins, "wings", and mounting accessories.
    When you open the box, the fuselage is completely painted in standard automotive base coat and clear coat for a super gloss finish. A removable canopy and nose section allows easy access to the battery and mechanics, and is factory installed with magnets and locating pins. This fuselage can be installed in as little as 4-6 hrs and is intended for the intermediate to advanced builder. No modifications needed when using compatible mechanics.
    • Fully painted fiberglass scale fuselage
    • Scale retractable metal landing gear (1 servo required to operate all 3 retracts)
    • Base of fuselage is reinforced with carbon fiber for added strength during a hard landing
    • Use of 500 standard equipment (6S Battery, 1400-1600Kv motor), fly with your existing parts
    • Roban B222 Airwolf fuselage without mechanics (this is a body only)
    • Scale retractable CNC aluminum landing gear
    • Side weapon set
    • Tail fins and wings
    • Mounting accessories
    Requires:Optional:Important Information - Please Read
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Advanced
    BUILD TIME: 4+ hours
    Class / Size 500
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1020 x 223 x 200mm
    Flying Weight 690g
    Main Rotor Diameter N/A
    Main Rotor Blade Length N/A
    Tail Rotor Diameter N/A
    Tail Rotor Blade Length N/A
    Tail Drive Type Torque Tube
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 3226-1400Kv Brushless Motor
    Electronic Speed Control 100A ESC
    Recommended Battery 6 Cell 22.2V 2600 - 3300 mAh LiPo Battery with XT60 Connector
    Required Radio 7 Channel
    Skill Level Advanced
    Build Time 4+ Hours
