Official Roban 500 Size SH-60 Seahawk Scale Helicopter Conversion Kit Thread
    • 8228
    SH-60 Seahawk 500 Size Helicopter Scale Conversion Kit from Roban - RBN-KFSH60SEA5
    This is the impressively appointed 500 class SH-60 Seahawk. Designed to take your Chaos 500 or Trex torque tube versions and transform it into an impressive representation of the SH-60 multi-mission maritime helicopter. This kit includes everything you need to install your mechanics, including the special shaft-driven raised tail system specially designed for easy plug-n-play install in the Chaos or Align mechanics.
    There are no extra parts to purchase to get this beautiful scale fuselage in the air. When you open the box, the fuselage is completely painted in standard automotive base coat and clear coat for a super gloss finish. Included are scale aluminum landing gear with working main gear oleo struts. Aluminum wheels and rubber tires give this kit a very scale look.
    Working sliding doors allow easy access to the mechanics as well as the entire top dog house being removable with factory installed magnets and locating pins. Designed for easy battery removal. This fuselage can be completed in as little as 4-6 hrs and is intended for the intermediate to advanced builder. No modifications needed when using stock mechanics and stock rotor head.
    When planning to use a 4 blade main rotor head and 4 blade tail, it is recommended to upgrade to a lower Kv motor and possibly a high voltage system using 8S (two 4S packs in series) or higher.
    • Fully painted fiberglass scale fuselage
    • Shaft driven tail elevated rotor set
    • Scale aluminum landing gear
    • Extremely detailed surface with molded panel lines
    • Use of 500 standard equipment (6S Battery, 1400-1600Kv motor), fly with your existing parts
    • 1150mm long
    • Roban SH-60 Seahawk 500 body kit
    Requires:Optional:Important Information - Please Read
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Advanced
    BUILD TIME: 4+ hours
    Class / Size 500
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1150 x 210 x 245mm
    Flying Weight 1280g
    Main Rotor Diameter N/A
    Main Rotor Blade Length N/A
    Tail Rotor Diameter N/A
    Tail Rotor Blade Length N/A
    Tail Drive Type Servo
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 3226-1400Kv Brushless Motor
    Electronic Speed Control 100A ESC
    Recommended Battery 6 Cell 22.2V 2600-3300mAh LiPo battery (required)
    Required Radio 7 Channel
    Skill Level Advanced
    Build Time 4+ Hours
