Official Roban 500 Size MD-500E G-Jive Red Scale Helicopter Conversion Kit Thread
    • 8231
    MD-500E G-Jive Red 500 Size Helicopter Scale Conversion Kit from Roban - RBN-KFMD500GJR5
    This is the 500 class conversion kit of the MD-500E G-Jive helicopter, a light utility civilian and military helicopter developed in the 1970's and still going strong today. Designed to take your Chaos 500 or Trex torque tube versions and transform it into a very scale RC version of the full scale helicopter.
    There is no extra parts to purchase to get this beautiful scale fuselage in the air. When you open the box, the fuselage is completely painted in standard automotive base coat and clear coat for a super gloss finish. Included are fiberglass landing gear and aluminum skids, a magnetic cabin lock system for quick access, transparent front window, and side windows that open for heat dissipation. Also includes tail fin parts, mounting accessories and landing gear.
    This fuselage can be completed in as little as 4-6 hours and is intended for the intermediate to advanced builder. No modifications needed when using stock mechanics and stock rotor head.
    • Fully painted fiberglass scale fuselage
    • Fiberglass landing gear and magnetic cabin lock system for quick and easy access
    • Extremely detailed surface with molded panel lines
    • Use of 500 standard equipment (6S Battery, 1400-1600Kv motor), fly with your existing parts
    • Roban MD-500E G-Jive Red 500 body kit
    • Scale fiberglass landing gear
    Requires:Optional:Important Information - Please Read
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Advanced
    BUILD TIME: 4+ hours
    Class / Size 500
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 780 x 175 x 308mm
    Flying Weight 613g
    Main Rotor Diameter N/A
    Main Rotor Blade Length N/A
    Tail Rotor Diameter N/A
    Tail Rotor Blade Length N/A
    Tail Drive Type Torque Tube
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 3226-1400Kv Brushless Motor
    Electronic Speed Control 100A ESC
    Recommended Battery 6 Cell 22.2V 2600 - 3300 mAh LiPo Battery with XT60 Connector
    Required Radio 7 Channel
    Skill Level Advanced
    Build Time 4+ Hours
