Official Roban 500 Size A-109 Blue and White Scale Helicopter Conversion Kit Thread
    • 8231
    A-109 Blue and White 500 Size Helicopter Scale Conversion Kit from Roban - RBN-KF109B5
    This is the 500 class conversion kit of the A-109 helicopter, a lightweight, twin-engine, eight-seat multi-purpose helicopter. The A-109 had the distinction of being the first all-Italian helicopter to be mass-produced. Designed to take your Chaos 500 or Trex torque tube versions and transform it into a scale RC version of the twin engine Italian-manufactured workhorse.
    When you open the box, the fuselage is completely painted in standard automotive base coat and clear coat for a super gloss finish. Included are retractable scale metal landing gear. The retracts are mechanical and require two additional servos (not included) to operate. Aluminum wheels and rubber tires give this kit a very scale look.
    Working sliding doors allow easy access to the mechanics as well as the entire top dog house being removable with factory installed magnets and locating pins. Designed for easy battery removal. This fuselage can be completed in as little as 4-6 hours and is intended for the intermediate to advanced builder. No modifications needed when using stock mechanics and stock rotor head.
    • Fully painted fiberglass scale fuselage
    • Scale retractable metal landing gear (requires 2 additional servos)
    • Detailed surface with molded panel lines
    • Use of 500 standard equipment (6S Battery, 1400-1600Kv motor), fly with your existing parts
    • Roban A-109 Blue and White 500 - body kit
    Requires:Optional:Important Information - Please Read
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Advanced
    BUILD TIME: 4+ hours
    Class / Size 500
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1020 x 223 x 200mm
    Flying Weight 690g
    Main Rotor Diameter N/A
    Main Rotor Blade Length N/A
    Tail Rotor Diameter N/A
    Tail Rotor Blade Length N/A
    Tail Drive Type Servo
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 3226-1400Kv Brushless Motor
    Electronic Speed Control 100A ESC
    Recommended Battery 6 Cell 22.2V 2600 - 3300 mAh LiPo Battery with XT60 Connector
    Required Radio 7 Channel
    Skill Level Advanced
    Build Time 4+ Hours
