Official RotorScale C127 100 Size Gyro Stabilized Helicopter with WiFi Camera RTF Thread
    • 8231
    C127 WiFi 238mm (9.3") Rotor Diameter Helicopter - Ready To Fly (RTF) - from RotorScale - RSH1008-001
    Click image for larger version  Name:	master.jpg Views:	0 Size:	39.6 KB ID:	357900
    The RotorScale C127 has a scale and profile that emulates the smallest RC helicopter in the world, the US military PD100 Black Hornet. Easily fly indoors or outdoors, the C127 also comes with a 720p WiFi camera to record your flights as well as a built-in gyro for stabilization making it easier for beginners.
    • Flybarless rotor mechanical simplicity
    • Built-in automatic stable flight system
    • The one-key takeoff and landing function allows beginners to operate easily
    • Low voltage alarm prompt
    • Out of control protection
    • 15 minutes of flight time
    • Intelligent module battery. (Remaining kwh LED display)
    • HD 0.3M (720P interpolation) WIFI camera
    • Durable construction
    • Cool LED headlights
    • RotorScale C127 WiFi 238mm (9.3") Rotor Diameter Helicopter - RTF
    • 4-channel 2.4Ghz Transmitter
    • 2.4GHz Receiver
    • Auto Stabilization System
    • 1S 580mAh 3.7V 25C Li-Po flight battery and charger
    • Hexagon wrench
    • Screwdriver
    Requires:
    • Nothing! Everything you need to fly is included.
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Class / Size Micro
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Plastic
    Overall Size (L x W x H) 230mm x 49mm x 70mm
    Flying Weight 73g
    Main Rotor Diameter 238mm
    Main Rotor Blade Length N/A
    Tail Rotor Diameter N/A
    Tail Rotor Blade Length N/A
    Tail Drive Type N/A
    Cyclic Servos N/A
    Tail Servo N/A
    Power System N/A
    Electronic Speed Control Integrated
    Recommended Battery 1S 3.7V 580 mAh LiPo (included)
    Required Radio 4 Channel 2.4Ghz Transmitter (included)
    Skill Level Beginner
    Build Time None
    Recommended Environment Indoors or Outdoors
